Results 1 to 20 of 20
Thread: LS3 Gold Blade TB on a LC9 Idle Issue
    Feb 2019
    SD
    26
    I have a gold blade tb 19420707 on my 2010 Suburban 5.3 and have a issues with the idle randomly bouncing around. It's usually just 100 rpms or so enough to hear it. I've change the Idle ETC Area Scalar from a 10 vette with a 6.2
    Aug 2006
    5BA8
    3,482
    Might wanna try swapping over the idle rpm PIDs from a Corvette or Camaro.
    EFI specialist
    email=[email protected]
    Feb 2019
    SD
    26
    they are the same
    Aug 2006
    5BA8
    3,482
    Quote Originally Posted by grandamle91 View Post
    they are the same
    I see it looks like you copied over a Vette file. If you compare to a Camaro, there are several tables that are different. One of my 2010 Vette files there were 1 or 2 different so I pulled one of the HPT repository and it looks like you copied that file over.
    I'd suggest maybe going back to your stock PIDs and see how it acts. It might work fine just setting the scalar.
    Another thing is, you softened up the idle spark control over/under tables. When you do that, it throws more of that responsibility back on the throttle blade. Might want to put those back to stock.
    EFI specialist
    Feb 2019
    SD
    26
    I'll try it again, it was worse with the stock lc9 pids, the under over weren't changed
    Aug 2006
    5BA8
    3,482
    I compared it to another OE file for 2010 5.3 and your over/under tables are definitely softer. The timing line graph in your data log you can tell they're pretty soft. Making them more aggressive should make the blade more stable.
    EFI specialist
    Aug 2006
    5BA8
    3,482
    Sure does look like they were changed last night around 8 pm.
    Actually they've been changed at least a couple times in just the past couple days.
    EFI specialist
    Feb 2019
    SD
    26
    I thought I switched it back to stock. Got that changed back, no difference. Only way I got it to idle smoothly was dropping the idle spark down to 13, but still randomly start to struggle to find a steady state
    Aug 2006
    5BA8
    3,482
    You or somebody has made extensive changes to the entire calibration. The only thing you posted about in your original post is that you have a gold blade LS3 throttle body. That's an insane amount of changes for a throttle body.
    Without knowing the rest of the build it's difficult to say what you got going on. It leads me to believe you're just too far "out in the weeds".
    Softening up the spark over/under tables will net a smoother idle, especially if you have a cam with some overlap. The side effect being the throttle then thinks it needs to move more to control your idle. Making the over/under tables more aggressive, or leaving them stock as opposed to softening them, will make the idle more choppy but it'll keep the blade from trying to control idle speed, and ending up with the condition you're in. Pick your poison.
    EFI specialist
    Feb 2019
    SD
    26
    guess im going back to the lc9 tb. idle fine on that
    Nov 2006
    2,875
    I'd put everything back to stock and then try it with the throttle body. You normally don't have to make many changes for it at all. Can get by with a scalar adjustment only.
    Tuner at PCMofnc.com
    Feb 2019
    SD
    26
    It's as stock as it can go
    Nov 2006
    2,875
    ???????????????????????????? doesn't look that way
    Aug 2006
    5BA8
    3,482
    Yeah it's not.
    It's kind of irritating you get half stories, half mod lists, posters claiming something hasn't been changed when clearly it has. Then when you make a suggestion all you get it "I tried that and same thing". OK whatever.....
    EFI specialist
    Feb 2019
    SD
    26
    Don't know how any stocker it can get, but ok
    2010 Chevy Suburban 5.3 12636005 e85 Trans Tuned.hpt
    Aug 2006
    5BA8
    3,482
    Judging by the change log you just put it back to stock before posting it.
    Where is the data log of it doing the same thing with it all put back to stock? At this point even if you posted one, I'd find it hard to believe you.
    EFI specialist
    Feb 2019
    SD
    26
    Then stop replying, I already said I figured it out. It didn't like the stock timing at 20. Doesn't hunt with it set at 13
    Nov 2017
    1,544
    Feb 2019
    SD
    26
    No Longer Responding. I remember why I stopped coming to this forum.
    idle 10 timing.hpl
    idle 20 timing.hpl
    idle 10 timing.hpt
    Aug 2006
    5BA8
    3,482
    EFI specialist
