Results 1 to 3 of 3
Thread: Tuning for air intake errors
    Apr 2021
    MD
    51
    When moving to more air I am finding we are getting some errors here and there like p222b.
    I was thinking it is related to the aircharge conversion.
    Jan 2022
    Southern California
    408
    I've yet to see that code, and I get a lotta codes. Barometric right? I don't even know where that sensor is located but I'd assume it would just be sitting somewhere in the eng bay, not touching the engine? So you're saying the code trips at full throttle or?
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    To fix the issue,
    the sensors located on the Air Filter Box are called Barometric Pressure Sensors most people tend to think they are MAF sensors which is on that case not correct !! As these platforms operates on MAP sensors and getting feeds from Baro sensors to calculate right amount of boost.
    I would suggest whenever replacing Air Intakes or Spark Plugs to replace them too as over time they may function but loose the ability to send correct signals to the ECU which cause P222b or loss of boost.
    Xstages Motorsport
    Tuning inquiries:
    ECU, TCU, CPC Online Tuning
    Whatsapp: +971503383340
    Email: [email protected]
    Insta: @xstages.motorsport
    www.xstages.com
