Results 1 to 10 of 10
Thread: Boost enrichment PE enabling very late
    Did a highway pull yesterday and was shocked to see that my commanded AFR was still stoich upon full throttle and passing through 100kPa. It remained 13.77 (1.07) until 5200rpm and 8psi of boost. I have no idea how I didn't knock. With my minimum MAP for boost enrichment at 90kPa, why was it still referencing the RPM table?
    (4:21 in the log)
    • 2001 C5 Corvette (625rwhp - Procharger, LS6 heads, Torquer V2 cam)
    • 1991 Volvo 940 - 2JZGTE (600rwhp - PT6466, HKS 272 cams)
    7,850
    There is a whole lot of weird going on in that tune file, I wouldn't know how to begin figuring out why it does what it does without reverting to something a bit closer to reality. MAF fail at 2KHz and the table zeroed above 2K? And that VE table sure is pretty but doesn't look like anything that would result from actual data collection and then tuning. Wowzers. Was this done by the kingtal0n method or something?
    Aug 2006
    5BA8
    3,481
    LOL
    PSA There's always been a delay switching to the boost PE in the GEN3s. That's why I set the RPM table up to command the proper EQ so I don't have to depend on the boost PE.
    Not switching tables until 5200 rpm is pretty late though.
    EFI specialist
    email=[email protected]
    Aug 2006
    5BA8
    3,481
    Your "NA" PE table isn't even set up correctly for an NA application. You're commanding stoich until 3200 RPM. Yeah that guy really knows his stuff.
    EFI specialist
    Aug 2006
    5BA8
    3,481
    You're not commanding any amount of fuel until about 125 Kpa. It's a combination of problems but basically neither is setup correctly.
    EFI specialist
    Aug 2006
    5BA8
    3,481
    This is how I would recommend setting them up.
    Luckily you aren't making much boost and the timing is on the conservative side for the boost level.
    EFI specialist
    I had lowered the RPM table but I see that was a bad move and luckily I didn't cause any damage.
    The timing was kept very conservative to try to keep the power close to 600whp since it's a stock block.
    For anyone else stumbling on this, I found this post from Chris which explains it well.
    https://forum.hptuners.com/showthrea...l=1#post246728
    Did you mean to post something else? Because that picture shows exactly what I had.
    This is what I changed them to:
    Aug 2006
    5BA8
    3,481
    Quote Originally Posted by phuz View Post
    Yeah that was the wrong screen shot. Should have been this one.
    EFI specialist
    Gotcha, thanks.
