Results 1 to 5 of 5
Thread: c5 corvette PE issue
    Jan 2023
    29
    Hello,
    I'm in the midst of trying to VE tune my c5 with a wideband. It looks like power enrichment isn't enabling as soon as I'd like, and I'm confused by that because I've changed all the settings to get into PE sooner. here's a log of the car and the current tune file. The other thing is as soon as I hit PE it starts retarding timing. Can someone point out what I'm missing?
    Thank you.c5vetteVE TUNING log 1.hplc5 vetteVEtuningVER2.hpt
    Aug 2006
    5BA8
    3,410
    Doesn't look like you changed anything but the minimum torque to zero. Drop the delay down below idle speed. Something like 200 rpm. Then it's just dependent on the throttle angle.
    EFI specialist
    email=[email protected]
    Jan 2023
    29
    Thank you....felt it was something stupid.
    Jan 2023
    29
    I have zero delay for that parameter, so it was just throttle angle the whole time. Do you have any insight for knock when at WOT? Noticing a spike in retard as when getting into PE and while under throttle.c5VE tuning log 4.hpl
    13,582
    Try turning off burst knock. Set the enable delta cyl air table to 7.900.
