Results 1 to 18 of 18
Thread: 16 GT 350 Hesitates for a second at 5-6K only 3rd gear up Help!!!!!!
    May 2021
    Pittsburg California
    35
    I have a 16 GT 350 this car has been an absolute nightmare can someone please help me!!! i bought this car brand new in 2016 and since then its gave me nothing but problems. i am on my 3rd engine that was covered under warranty. car is no longer under warranty though i dont believe it to be a bad engine at wot it will hesitate between 5-6k and will resume fine all the way until redline,i have replaced the intake, coils, injectors, wiring harness, spark plugs gapped to 28, and new crank sensor and i did do a neutral crank learn. and nothing will fix the issue. when in first gear or second issue does not happen or if i have redlining the car and do a quick shift to keep it above 3k rpm it also does not have an issue. i have also seen while ideling the vehicle does misfire and i can actually watch the misfire counter go up. i am not very good at reading pids but i did notice i got a misfire at wot and timing dropped to 3.5 deg. could someone please review my scan and tell me what they think? also my transmission is a tremec it is not the orginal it has a slip yoke instead of the drive shaft flange so it is not the loose nut tsb i am getting no codes. 1st part and last misfire madina.hpl
    Oct 2016
    Poland
    1,761
    I dont see anything strange but you dont log much. Use this list and repeat.
    May 2021
    35
    ! i went for another drive 2nd gear pull no misfire 3rd gear pull misfire new pid lis
    Thank you for the reply! i went for another drive 2nd gear pull no misfire 3rd gear pull misfire and another 3rd gear pull with a misfire16 mustang gt350 misfire.hpl
    at 77 mph timing was reduced to 2 degrees. Could that be traction control? Spark source switched from borderline to torque control. Try turning it off traction control and repeat.
    Dec 2017
    767
    Is it boosted? .028 is very small gap for a n/a motor
    Oct 2016
    Poland
    1,761
    For some reason you are hitting oscillation/anti shuffle which cuts timing in the middle of run - this is very very strange and IMHO tune related.
    Jan 2013
    Hawaii
    2,101
    Trouble Codes:
    P0100 - Mass or Volume Air Flow A Circuit
    Mass air period barely reaching 300 microseconds in deceleration conditions and 130-120 at WOT, I would say its reading incorrectly, or you have it in an incredibly dynamic tube size. Is this a stock OEM MAF sensor?
    May 2021
    35
    Hello thank you for the response I did turn off traction control completely I thought that might be what it is as well because everything time the issue occurred timing has been reduced significantly but I watched for the traction light to come on it never did and I held traction control off for 10 seconds did not help
    May 2021
    35
    Replaced 2 factory mafs in a cod air intake put stock intake back in same issue
    May 2021
    35
    N/a
    May 2021
    35
    No tune factory tune
    May 2021
    35
    I have had so many people look at this and can not understand what is going on I know a little and I am completely lost here I do have a feeling it has something to do with aftermarket tremec transmission also installed a McLeod double clutch. But why I say it’s possibly the transmission is this issue occurred shortly after transmission install and if you look at the tab for tone ring coming lose on the stock transmission it has the same symptoms misfire/hesitation only at 5-6k and cruise control don’t work I understand it’s a different transmission but both transmissions are not getting a correct reading from the output shaft?
    Oct 2016
    Poland
    1,761
    So it was not tuned for new trans?
    May 2021
    35
    As far as I remember no! but I am trying to verify with the shop who installed the transmission.
    May 2021
    35
    I really appreciate your help I finally feel like I am getting somewhere! I did some research on the anti shuffle of these cars and I seen quite a few post about this issue and turning this option off to resolve. Would you recommend turning this option of to resolve so it at least gives me somewhere to start from? Could this damage anything?
    Sep 2022
    Clearwater FL
    212
    Yes anti shuffle should be off
    Oct 2016
    Poland
    1,761
    So the anti shuffle might be a result of you not changing the gear ratios - turn the anti shuffle off. This is a good function but your tune has to be perfect to use it.
    May 2021
    35
    More info when installing a new aftermarket transmission I was sold a bowler Bluetooth module that is supposed to convert the gear ratios and output shaft signal to the factory specs. I am going to do a little more investigating on this module thank you guys for the help you guys are way smarter then dealerships!
