OK I was able to implement "Verlon Mode" pretty quickly!
Here is the starting shape defined with the full 6 coefficients
Here is the attempt to mirror that same shape with only 5 coefficients
They look identical! I put the new and old VVE literal values in a spreadsheet and compared the values, the min percent difference is -.52% and the max difference is .30%! That is a total error of .82%...less than a percent! I was not expecting that at all. The downside of using my tool in Verlon mode would be that you would have to copy all 5 coefficients by hand because if you pasted the VVE values and calc'd coeff, HPT would break it down into 6 coefficients.
Unfortunately with my new found transmission issues, I won't be able to test for a while. So if anyone wants to test a 5 coefficient Verlon work around mode hit me up with your numbers and I will generate them.
