Results 1 to 8 of 8
Thread: FI 2005 Silverado L33 Thermostat Question 187 to 180 Require Fan Setting Changes?
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    Hello,
    I have 130k miles on the truck and a spare 180?F T-Stat I've had since 2006 and never installed. I want to change it before it fails and leaves me road side.
    If OE is 187?F and the spare is a 180?F and I swap it in would fan calibration settings need to be done
    T-Stat shelf life?
    Thanks.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Mar 2009
    Andover, MN
    499
    Probably should be in Gen3 forum. And yeah, I'd adjust the fan on/off temps to the tstat.
    Jun 2009
    N. GA
    530
    Thanks, I was going by this "Forum: GM V8 Tuning - Engine, Gas (Gen 4) (2005-2015, LS2, LS7, ...)
    Drop them all by 10?F?
    Mar 2009
    Andover, MN
    499
    Well if the tstat is 7 degrees colder, i dont think id do 10 lol. There are about a hundred threads on fan temps. It used to be a Sticky, but i didnt find it. Usually an 05 Silvy is a P59, which would be a Gen3.
    Dec 2019
    MS
    568
    Just drive it. You dont "HAVE" to change the Fan temps. When your moving the Coolant temp will stabilize, see what that temperature is.
    Then decide on where to set the fans if you do change the temps.
    Jun 2009
    N. GA
    530
    Thanks, I'll search more. With only 7F difference it shouldn't be critical I guess.
    Here is a blast from the past. Perhaps Motorad made a good product back then.
    5BA8
    3,446
    I would not drop the fan temps. I would not install a 180 stat. This is not 1983. We aren't tuning cast iron headed small blocks. These engines are designed to run hot and run better hotter. Running them too cool actually causes problems in the long run.
    email=[email protected]
    Jun 2009
    N. GA
    530
    Thanks, I was surprised to see the OE shown at 187F. I'll take said advise.
    I'm going to be in there soon.
    She has been demanding my attention lately. @100k I found a radiator hose bulged, changed them all. Recently seen a small trail of dried coolant on the front of the engine, probable WP or gasket.
    In process now of determining if an oil leak is the rear main, or oil cooler in/outlet gasket, or crankshaft position sensor. And yesterday I completed changing the right front inner CV axle seal that made a mess.
    All cleaned up now waiting for the test driving show and tell. She has been good to me. Purchased new and blower installed @5k miles she has been driven spirited constantly and trouble free.
