Results 1 to 4 of 4
Thread: Can someone look at my log ?
    Nov 2023
    6
    Can someone look at my log ? 6.4 cam swap 09 ram 1500
    SO recently i did a 6.4 cam with performance springs a new 6.2 oil pump with the MDS delete currently running a tune. First start my map was showing over 90 kpa , i took off the intake manifold looking for a vacuum leak and reinstalled it and it droped to 58-60 kpa. Is this normal if not what can be causing this issue?2009 ram 1500 rev4.hpt2009 ram 9th start.hpl
    Tuner vndetta79's Avatar
    Aug 2022
    Houston, TX
    79
    Looks pretty normal, maybe slightly high but your idle speed is lower than what I run with a cam. I idle @ 750rpm with MAP @ 53kPa.
    Nov 2023
    6
    That?s good news I?m going to try and bump up desired idle speed to 750 and go from there. How?s my timing advance ?
    Aug 2022
    Houston, TX
    79
    I don't see any changes in the file to your timing. Looks stock. There nothing to really see with the timing in the scan because is only idling. I can say the it looks lean and there's an issue with your Bank 2 O2 sensors.
