Hello, Trying to correctly enter all the injector information and hoping someone can help me, make sure all is correct.. Thanks in advance!
FIC 1200cc
FIC 1200cc
There's something wrong with that file they gave you. Look at the offset. How's it increasing with voltage? The LS2 stuff looks legit. If you compare the two SPA tables the adders don't cross reference with their columns.
When you obtain good data only use the 0kPA column for IFR and Offset. Copy those values straight across to the rest. This is because of the vacuum referenced reg on your truck.
The Ford stuff is screwed up, too. Testing should've been done at 39.15 psi instead of GM 58 psi.
You're not given a Min Pulse, either.
Contact their support.
Up to you. Might contact them first. Their support is pretty responsive.
This is what I was sent for compare.
That's more like it.
Don't forget Fuel>Transients>Min Fuel Milligrams. It will come to around .014 for these.
