I'm replacing the ECM in my 2007 suburban but i have a tune on old ECM, what the process can i read the tune off old ecm and write it to the new ecm.
Read current tune and save it
Install new ecm, have it updated.
Then read that tune off and do a comparison.
Change whatever you need to change with the comparison
Stop making threads that you've already asked questions on.
Exactly what RDF1 said.
Theres a compare feature at the top of the editor. Open the new PCM file, then click the compare button and load the original tune. Anything different will be a different color and you can copy all the values over so itll match in the areas you need.
"I don't care how it runs as long as it chop chops at idle"
