Results 1 to 4 of 4
Thread: 2016 3500hd 6l90 trans replacement
    Nov 2011
    15
    My buddy is going to be replacing the transmission in his truck. My research shows it will need to be programed. Can I download stock file from old trans and drop in the new reman trans. Basically thinking a read all and flash all deal. I'm not able to find much on this topic so thanks for the help.
    Nov 2011
    15
    Bump
    Jan 2007
    Chicago/Henderson Nv
    14
    Highly suggest hooking up with someone with a MDI from the dealer. The replacement serta trans usually doesn't have a good base in the tcm or sometimes they have nothing useable. They can be done with a HPT device but often it misses data. I suggest paying the dealer if you can't find someone with gm access to techline connect.
    Revsc.com
    Aug 2023
    SoCal
    472
    It all depends on the TEHCM in the transmission. If is blank like a new one, then it will not work. However, if it is a use one that was used during the reman process, then yes you will be able to transfer the program over from your old TEHCM.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
