I've got a Gen 3 F150 with a Loki blower kit I'm tuning and I'm getting railroaded when it comes to the injector data. Is there any information or data available on these?
Here are the values for stock 13-14 gt500 injectors
Make sure you have the same measurements selected when inputting the data. Its on the side of the boxes you input the data if they aren't matching you will be inputting incorrect data.
Also you can usually just put 1 for the rail temp multiplier if your vehicle does not have a actual fuel rail pressure / temperature sensor.
I'm an idiot. Whipple uses the same injectors and I pulled the data off their stage 1 tune. Works perfect. Quite a bit different than published because of the higher pressure fuel system on the low side.
