Results 1 to 20 of 39
Thread: 2017 5.7 Hemi Tune assistance Cam, lifters, Injectors
    Jul 2023
    23
    Here it goes.
    1. Truck Norris cam 212/23x
    2. VVT limiter -4cam
    3. hellcat Non MDS lifters
    4. long tube headers
    5. 35 lb/hr injectors. unless you know a better combo for above.
    I'm relatively new to this. I have the MDS disabled. need some assistance with the tune
    Potential Tuner N2 Speed's Avatar
    Feb 2019
    Florida
    5
    your stock injectors are fine for that combo
    Jul 2023
    23
    Thanks For the confirmation, I'm looking for some assistance with a base tune to get me started. should be back together soon
    Post youre tune file for your car
    2019 challenger rt
    k&N cold air intake
    92mm hellcat throttlebody
    ported 392 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers and catless mid pipes
    3' catback with h-pipe & pypes violator mufflers
    e-85 tuned
    3.70 lsd
    Jul 2023
    23
    Any thoughts?
    here is a tune that i think should get you started up. its based off an old cam i had that was similarish in specs, so should start and run long enough to get a log. also dont know if you have cats or not, so i didnt disable any of that
    2017 Dodge 5.7 truck norris startup.hpt
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
    Jul 2023
    23
    Thanks James! this came at the perfect time. I will keep you posted, and if its ok can I give you a shout out, this project is part of a video series on my YouTube channel. https://www.youtube.com/@robinsonsauto
    Alright, let me know. Not sure how well it will run though, but the tune ran good on mine, but every car is different
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
    Jul 2023
    23
    That got her running! She?s an eye burner at the moment. Here?s a short clip. I have the stock fuel injectors in it and it has a -4cam VVT limiter in it. not sure if it?s something to do with the VVT as well.
    Jul 2023
    23
    start up tune.hpl im still trying to get the video uploaded here
    Thats just the fueling that needs dialed in. But with it running, that can be dialed in. You know how to tune the fuel ttims correct?
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
    Jul 2023
    23
    I'm learning as i go any assistance would be greatly appreciated
    Ok, i beileve there is a thread on it here. But you need to make a math parameter of long term - short term fuel trims for bank 1 and 2, then you can copy and multiply by half into the ve tables
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
    Jul 2023
    23
    thank you, another question. since this is a VVT camshaft with a -4cam limiter. is there more i should be taking into consideration?
    For the vvt, most keep it fully advanced(dodge uses the exhaust tables, so its backwards) of 125, till about peak torque, then retard to the shift point. Ive adjusted it in the tune, but if youre on a dyno, you can fine tune it better. You can check the compare files to see the diferences. If you are worried about fuel milage, i believe you can retard it a few degrees to bump up the mpgs
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
    Aug 2021
    Yorktown VA
    200
    This is all great info right here. Only thing I can think to add is to make sure that you log the parameter "Exhaust Cam Center Position" in VCM scanner to verify where exhaust cam full advanced is for your set-up. Because you may find max advanced to be 128, depending on your cam, in which case you would just keep it fully advanced at 128 until peak torque and then retard from there down to 124, based on the limiter listed in your description.
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
    Dec 2018
    Florida
    36
    Most the guys here are very knowledgeable and their are a handful that truly don't mind helping others are all about the money and if this forum was about just putting your business out there that's on that person however if their is a way to help someone else let alone someone starting up tuning that's a true enthusiast.
    Jul 2023
    23
    Just now seeing this! thanks for joining the discussion. truly appreciated. this has been a steep learning curve for me, i have the fuel trims at idle looking a lot better but the timing needs attention I believe. it will be another long night of studying for me. sorry I didn't catch this in time but tomorrow I will grab a new data log including exhaust cam centering position. here is a log from todays efforts idle trims close.hpl
    Jul 2023
    23
    very true. Id be lost it it wasn't for James jumping in to help initially. truly thankful
