Having a bit of an issue here. I was able to read tune file alter tune file write changes and start vehicle while scanning. After about 30 seconds scanner lost communication and I can?t seem to regain it. My little bs 50$ scanner connects reads and clear codes and does everything it?s supposed to do but my hptuner device just will not connect. Can?t load any scan data as I wasn?t able to collect any. I can load the tune file if it may be of some use. I have confirmed battery volts and grounds are good at obd connector and data wire must be functioning for my other scanner to operate. I have restarted my laptop and resynced my device as well.
