Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Fuel Pressure for Vehicle Swaps
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    553
    What is the best way to deal with a non-GM fuel system with different fuel pressures on a vehicle swap and no FPCM? I am guessing these two fields are needed:
    [ECM] 13541 - Minimum Rail Pressure
    [ECM] 13542 - Maximum Rail Pressure
    Then hook a physical gauge to the rail to get pressure at idle for max and go another reading at WOT for max?
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
    Jan 2014
    SoCal
    1,596
    Different fuel pressures typically I just run the injector through the online calculator to change [ECM] 12307 - Injector Flow Rate vs. Pressure Delta:
    https://www.rcfuelinjection.com/technical
    Aug 2021
    553
    Quote Originally Posted by TheMechanic View Post
    OK interesting, so if I have an LS3 injector (42 lb/hr @ 58 PSI) and it is now operating at 30 PSI, the new flow rate (according to that calc) is 30.21 lb/hr...
    Would I want to multiply the entire table by 0.719 (which is 30.21 / 42)?
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    7,886
    You can take real injector flow rate (and Offset, too, which is HARD to interpolate for a different fuel pressure independently!) from a tune file that used those injectors and has all the tables fully populated with real data (not placeholder data, like in some of the 2006-2007 files).
    Aug 2021
    553
    Not sure I am following you...are you saying there were factory '06-'07 cars with LS3 injectors running on 30 PSI fuel pumps and I can copy that data? I thought all Gen4 stuff was nominal 58 PSI?
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    7,886
    The ECM doesn't know what the rail pressure is, without a FPCM it will assume it's 58 (400 kPa). And it will only use the cells in the tables that go from 400 (or 408) to 480 (or 488). I don't think it will adjust to using the correct cells by just changing the numbers for the Min/Max rail pressure.
    What ECM are you working with? Early with 128-640 range or late with 128-788?
    Aug 2021
    553
    Later 128-788 style. I was trying to fix the 58 psi assumption by altering the pressure min/max fields...but I guess that is not possible?
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Jul 2020
    VIC Australia
    1,182
    With no fpcm your easiest route is a manifold referenced reg. Flatline the ifr appropriately, use the ls3 data for the remaining inj tables like blindsquirell said and go hooning.
    7,886
    It'll work fine returnless at 30 PSI* as long as the data is taken from the right pressure Delta range. For 30 PSI returnless that would be the columns from 208 to 288 kPa, pasted into the columns that go from 408 to 488. It's just shifting the data over into the columns that will actually be used.
    * assuming the spray pattern doesn't go to shit when run at half the pressure they were designed for
    Aug 2021
    553
    The other side to this problem is that the fuel pressure is flatlined at 399 kpa / 57.9 psi all the time at idle, CL, and PE. It never moves. What controls the fuel pressure estimation (E67 btw)?
    Here is a log that is 34 minutes of driving. Perfect pressure!
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    7,886
    It's a fake value, it's just assumed to be that and all the pulsewidth calcs are based on that number.
    7,886
    And I'm curious, what kind of fuel system runs at only 30 PSI but still has enough volume to support whatever HP this is?
    Aug 2010
    Detroit, MI
    947
    If you have user defined parameters, you can hunt down the fixed rail pressure calibration. And injector cal would be handled just like blindsquirrel said.
    Aug 2021
    553
    Right. Exactly.
    In the real world pulse width (aka flow) increases and pressure decreases. So why would this ECM assume constant 400 kPa pressure even at WOT?
    And once I jiggle the handle on the IFR v Pressure...the ECM still won't calculate pulse width correctly because the fuel pressure is assumed to be flat lined.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    7,886
    Fuel pressure is constant, the pressure delta across the injector is not! Delta changes constantly with manifold pressure, therefore flow rate (& Offset) does too.
    edit: And the ECM knows the Delta at whatever point in time, because it has a MAP sensor.
    Jul 2020
    VIC Australia
    1,182
    The secret sauce. I understand the method now blind squirrel. Thanks for explaining all that.
    Tuning Addict
    Jan 2015
    6,869
    Quote Originally Posted by smokeshow View Post
    Seems like you would still need to do this part for the ecm to fully know wouldn't you? Of course I guess as long as you shifted everything it wouldn't matter? Or would it still apply the short pulse adder based off of the higher pressure reasoning?
    ~Greg Huggins~
    7,886
    SPA is PW-based, only IFR & Offset reference the pressure.
    Tuning Addict
    Jan 2015
    6,869
    Yeah and I guess as long as your correcting those they in turn correlate the other. I was just wondering if there was a background table playing into the injectors correction based off of calibrated pressure. You're correcting it either way using Blind's method, so don't guess it really matters.
    ~Greg Huggins~
    Jul 2020
    VIC Australia
    1,182
    Found it.
    There are 7 switches in total. Default, hot, crank, high flow, cold, low flow, normal. They are defaulted to off. When switched on, the ecm will use the respective fuel pressures in [ECM] 7030 through 7035
