Brand new to e90 ecm tuning, have a stock engine with btr dod delete kit. Ecm has already been sent off and i have the stock tune file but i am lost on where and or what to do o turn dod off? Any help would be greatlappreciated.
Just DOD? It's the rpm settings under the Fuel tab.
~Greg Huggins~
thanks for the reply i looked under the variable cam table but i have not seen the rpm setting or tab that you are talking about. I did see something that says misc desired angle and it has a smaller tab that says high dod is that were you are refering to? It has the rpm graph would i just zero that out?
Sorry, it's under Fuel, not cam - lean fuel setting - Leave as sliding if still variable cam too -
Last edited by GHuggins; 02-06-2024 at 02:17 PM. Reason: corrected my earlier post
~Greg Huggins~
Would i just put rpm to 1 or something low
The picture I posted is out of one of the one's I've done. Just set it to 0. Leave sliding as sliding if running variable cam.
~Greg Huggins~
Sorry didnt see the picture. I will try that in the morning thanks a million times over
Hello im attempting to do the same but i dont have the option for lean/fuel.
