Results 1 to 20 of 24
Thread: How many of you guys are tuning with Narrow bands on Idle and light cruising
    Jan 2023
    254
    Just curious how many of you guys are using the factory narrow bands to tune idle and light cruising with Short and Long term fuel trims Vs Using a Wideband in Lambda with EQ ratio?
    To me the wideband seems like the better way to go for idle and light cruising as opposed to the narrow bands.
    Is there a specific reason to use the narrow bands?
    Obviously only a wideband can be used for Power Enrichment as the narrow bands cant.
    Aug 2009
    Calibrating
    3,377
    Unless you’re tuning full time OL, let’s the narrow bands do idle and part throttle
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Dec 2019
    MS
    568
    Quote Originally Posted by Allen Vos View Post
    Are you going to enable the narrow bands once your done tuning with wideband?
    Ive tuned some with wideband then used narrow bands to confirm everything aligns with the info i got from the wideband.
    Aug 2021
    865
    +1 for fuel trims.
    5BA8
    3,430
    Werd.
    email=[email protected]
    Aug 2021
    550
    Since the ECM uses narrowbands to determine the fuel trims during closed loop, so should you. You are tuning to make the ECM happy, not the dubiously accurate wideband.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    5BA8
    3,430
    "The PCM doesn't care what your wideband thinks!"
    Feb 2018
    830
    NBs here for all of my CL tuning...then WB for OL/WOT stuff. I've never understood why guys tune fully with a WB for a CL tune....only to have the NBs come back in and start making corrections
    Jan 2023
    254
    Fair enough guys. The masses have spoken.
    Narrow bands it is. lol
    It does make sense to tune with NB as the PCM will use that all the time for correction which I will leave on.
    What is better, tuning with STFT only or STFT and LTFT?
    Or does it really matter?
    Jul 2020
    VIC Australia
    1,174
    Ltft carries over into open loop. 6 of one half of the other, I turn off ltft and just use stft.
    Jan 2023
    254
    That is exactly what I wanted to hear.
    I tried STFT + LTFT and had a tough time getting things set correctly.
    As soon as I only did STFT I had good results.
    Which is why I asked If it made sense to tune with a Wide Band.
    Thank You
    Aug 2021
    865
    What I have found that works well for me is to use STFT + LTFT to get all the data. I then create a graph for LTFT ONLY and make corrections based on the LTFT's. This has helped me to sneak up on my fueling since I filter data then use the LT's, which is an average in itself, from what i understand. I was shocked to find out just how much more violence was left in the motor.
    Jan 2023
    254
    Quote Originally Posted by LS ROB View Post
    So maybe STFT is better to help mold a basic tune, and adding LTFT puts the finishing touches on it then LTFT only really fine tunes it?
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    217
    I know people say this but I have never actually seen it change my OL fueling. I have had 15% positive LTFT's and PE was exactly what I set it too.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
    Mar 2021
    217
    I have done it both ways. I have found just using STFT is a bit quicker to get a clean VVE table. I also have not seen the postivie LTFT actually change PE in OL like many say it does. But to be sure most using LTFT just make sure trims are negative 0-5% since only positive fuel trims pull over to OL.
    Sep 2021
    483
    I normally tune in ol with wideband, set to stft only when done. I dont need ltft when my fuel trims are +/- 2. I do tune closed loop, stft only, with wideband for the wot stuff on email tunes. Makes it safer for the inexperienced eyes and right foot on the other end. If im getting results using my ballenger and aem widebands why change it up?
    Aug 2021
    550
    I just turn LTFT off and keep them off. If you are ever "done" with tuning then turn them on. But the hard part of tuning, logging, revising the tune, driving, logging, etc is that you need to reset the LTFT learned values in the scanner before you drive and log each time (at least if you are making air/fuel changes). This is easy to forget and adds extra time and steps to the tuning process. And if you forget, then the potential for error starts to creep in your tune which will delay final results and have you going in circles.
    The other argument is that the last LTFT value that is active will be carried forward into PE fueling. I have seen this happen on my E38. Which then throws off your attempts to calibrate PE air/fuel.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    2,821
    Only the positives do.
    GM has been doing the same since the chip car days.
    Tuner at PCMofnc.com
    Aug 2021
    550
    Thanks for the clarification!
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Aug 2009
    Calibrating
    3,377
    LTFTs off or keep the fuel trims little negative and keep them on
    14 Gen 5 Viper
