Results 1 to 10 of 10
Thread: L83 Chopacobra "need more chop"
    its not real choppy at all would like to get a steady chop if possible new to gen 5
    tuner said thats all the chop that it will do as its not too big but i just thought with a 108 lsa it would chop really good even thought its only 214/228
    would like it to idle like this
    https://www.youtube.com/watch?v=CjE4EEwZUu0
    Tuning Addict
    Jan 2015
    6,867
    Datalog?
    That is a different gen truck from the looks of it and you can tell it's being forced - goes into a timing / O2 swing chop at the end. You can force crazy crap on the gen V's too, but sometimes it bites you for drivability.
    ~Greg Huggins~
    it chops decent in park or neutral but im forcing it
    theres no chop if i put it in gear. i can see the timing stops swinging when i put it in gear, what does predicted tab do under idle>rpm>speed control. have not messed with this
    Datalog?
    it is a 2014 silverado gen 5 l83
    Tuning Addict
    Jan 2015
    6,867
    You still haven't dialed anything in? Predicted is throttle control. Immediate is timing control. Trucks start to ignition knock bad if you try to overly use timing control for higher rpm errors FWIW.
    ~Greg Huggins~
    Sep 2021
    Lexington KY
    199
    stock converter? those cams work better with a higher stall. you can get them to chop more if you like, and drives way better too. just my opinion
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    140
    You have too much timing/throttle control for the "in gear" areas and converter needs to be loosened up in the tune. Idle will always chop more, but they can chop in gear stopped and when coming down from about 3mph to stop. Chop will go away once you start moving 3-5mph typically. Sounds like you're looking for the chop for pulling into the car meets barely rolling?
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
    Aug 2006
    Arizona
    266
    If you're desperate, run in open loop and lean out the idle areas you want more chop from. Or you can do it the right way and get a higher stall converter.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Sep 2021
    496
    That ho spark map and the e85 spark maps need to be gone over. Several other wacky things in there.
    Jul 2023
    3
    Quote Originally Posted by ctsv2011 View Post
    A camshaft is mechanically defined at the time it was ground( made). The lobe center or overlap between valve events will dictate the "chop" you're speaking of so it is what it is. Looks like a 106 degree from your information above. With a modest duration as you show here and a 106 overlap, it will chop Now if you go dumping a ton of fuel into the engine it'll chop more but that will be limited because you'll like wash the oil off the pistons and cylinders and seize the engine pretty quickly, the same is true if you're starving the engine for fuel. Make sure you have enough fuel pressure and injectors with enough flow to feed the beast. Check your spark advance. The cam should have some timing information with it. If a mechanic installed it for you, you might ask if he advanced or retarded the came timing on install and how much. I know which cam you're speaking of and the Chopacabra is indeed pretty lumpy at idle. There are several things that can effect that really. Valve springs, compression, timing, the AFR, and I'm no expert. Others here may have some more information for you.
