Results 1 to 8 of 8
Thread: 2010 up sierra Fuel Pump Control Module question with hard wiring pump
    Feb 2013
    32
    hey guys been trying to search this answer
    2010 sierra 4.8 with TVS 2300 blower and 56lb injectors flexfuel pump at 7psi and im running out of fuel .
    Options are
    Replace fuel line with larger line
    replace fuel line larger and do FPR on firewall and hardwire pump .
    What do i do to the setting in the Fuel Pump for the hardwire ?
    13,647
    I don't think the fuel line size is the issue, guys with 6.2's and blowers can make great power on the stock fuel feed line.
    I'd be looking at the pump if it can't provide enough fuel pressure for the power you are making. Was your truck factory flex fuel? I thought those came with bigger pumps that can support like 500hp.
    Feb 2013
    32
    yes the truck is a flexfuel setup and everything i read online was there good for around 600hp could be wrong i dont think im making 500hp yet lol
    my issue is i put in a slighly bigger pulley and my duty cycle is at 97% and fuel pressure is dropping 6psi.
    have another friend who is having same issue his was dropping off 12psi
    Apr 2016
    331
    Have a 6.2 with 2.3L Whipple, 7 psi, and the stock flex pump was enough IF running “gas”(E10), but the whipple supplied GM 50lb injectors were over 100%. 72lb injectors fixed that. But on E85, the 72lb’ers and a Walbro 450 were both maxed out. If you think you will EVER run E85 , ( and if you’re already playing with pulleys you will),then best to plan an entirely new fuel system. Otherwise you’ll be doing it again, and good big injectors are expensive. Price of injectors takes a big jump when you go above 100 lbs.
    1,858
    Is the “good for 500hp” supposed to be for NA or boosted”?
    Feb 2013
    32
    Quote Originally Posted by NotSure View Post
    thanks for the response, what did you do to your fuel system ?
    i would like to put in my LC9 with BTR cam and maybe 10-12psi but want to figure out the fueling before i do this.
    i was thinking of running a larger feed line to the front with a FPR on the firewall use the oem feed line as a return as it has the E Content sensor in it, replace the fuel pump with a 450LPH and just dump the return thru a bung drilled into the hat .
    Other question is what do i do with the FPCM so i dont get a CEL ??
    Apr 2016
    331
    Nothing yet, but plans to do dual Walbro 450's, one boost activated, with a full return system, and 1300cc injectors. I plan to run the primary fuel pump through the FPCM, since that circuit is already using heavy gauge wire. You can change some settings in the FPCM to run it in this manner, but you will have to use 1 credit to license the module if you haven't already. Haven't done it yet but the info is here in this forum. I can tell you that trying to run the Walbro 450 as a PWM in a returnless system does not work so well.
    3,172
    Quote Originally Posted by jdmcrx View Post
    Options are
    I would think the stock pump should cover that. It might not be just due to age. It is 14 years old at this point.
    Tuner at PCMofnc.com
