Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: L83 DoD Delete Help
    Mar 2024
    11
    We have been using a temp gun. 1, 4, 6, 7 are about 180-200. 2, 3, 5, 8 are 450-500*
    So it still acts like the DoD cylinders are not firing.
    5BA8
    3,478
    Pull the valve covers and do an inspection. Disable the injectors and coils and crank the engine through and watch the rockers and make sure all of them move equally.
    Check lifter preload. Make sure no valves are hanging open. At this point I would not consider it a tuning problem. Need to diagnose it mechanically first.
    email=[email protected]
    7,847
    If you still have the old VLOM, plug it into the harness and see if anything changes.
    Mar 2024
    11
    Just wanted to reply since I don?t want to leave anyone else with this possible issue hanging.
    Broken intake valve spring on #7. Replaced it and problem solved.
    Arizona
    492
    Quote Originally Posted by Immortan View Post
    So that answers the what question for cylinder #7....what about 1, 4, and 6?
  6. #26
    Mar 2024
    11
    Quote Originally Posted by bk2life View Post
    #7 was acting like an air pump, or essentially a big vacuum leak and those must have been the most affected cylinders.
