Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 90
Thread: Lost injector info
  1. #21
    Tuner bsaathoff73's Avatar
    Nov 2023
    Nebraska
    53
    here it is
  2. #22
    Mar 2022
    Indiana
    3,019
    Are you able to remove the wideband and put the narrowband back in?
  3. #23
    Nov 2023
    Nebraska
    53
    The o2 sensor on my exhaust?
  4. #24
    Mar 2022
    Indiana
    3,019
    Yes. You have one in the passenger side. Driver's side you took it out and put in a wideband right?
  5. #25
    Nov 2023
    Nebraska
    53
    Yes i can swap it back out. Want me to do it now? If so. Give me a hour to get it done. Just gotta grab my tools n jack quick.
    Want me to pull a log after?
  6. #26
    Mar 2022
    Indiana
    3,019
    Not yet. I'm getting things together for you. Which cam? MAP sensor P/N (or vehicle it's from)? Overbore?
  7. #27
    Nov 2023
    Nebraska
    53
    Ok. Just gimme a holler and ill swap it out. Got stuff pulled up front now to do it.
  8. #28
    Mar 2022
    Indiana
    3,019
    Get rid of these two airflow channels. Should only be using the 2bar.
    Include Dynamic Airflow, IAC Counts, Idle Adapt (STIT), RPM, MPH.
    Log this. Just let it idle up to temp then get a quick 5 minute drive this first time around. Keep it below 3000rpm. Stay out of boost. Ease into it. Watch for KR.
  9. #29
    Nov 2023
    Nebraska
    53
    You want me to put the narrow band in before i drive?
    KR, knock retard?
  10. #30
    Mar 2022
    Indiana
    3,019
    Yes of course.
  11. #31
    Nov 2023
    Nebraska
    53
    Got dynamic airflow, idle adapt (stit), engine rpm (sae), vehicle speed (sae), idle air control position added. If correct i will fire up, let warm up, go for a short drive n log it.
    Got the narrowband back in also.
  12. #32
    Mar 2022
    Indiana
    3,019
    Sounds good. Ready when you are. Might have to lock it into D2 to get up to 3k without boost. Slow steady pedal.
  13. #33
    Nov 2023
    Nebraska
    53
    Headed out now to start it up. Slow n steady. Got it. And try n get it to 3000 rpm but smoothly
  14. #34
    Mar 2022
    Indiana
    3,019
    Use that tune I posted.
  15. #35
    Nov 2023
    Nebraska
    53
    I didnt get to far. heck of a lot farther then prior though!
  16. #36
    Nov 2023
    Nebraska
    53
    I will redo. Just seen the other tune. I was on my phone earlier and it didnt show a attachment. Not sure if I just do write changes or write whole thing so I write whole thing.
  17. #37
    Mar 2022
    Indiana
    3,019
    Write Calibration.
  18. #38
    Nov 2023
    Nebraska
    53
    Thanks. Start up, pop, pop, pop is what its doing. I'll fire it up in the morning. My neighbors came over and complained. Its straight pipes by my axles right now. Pretty loud at night lol. I got a start up log. Pretty small. I'll ad it. Gimme a sec
  19. #39
    Nov 2023
    Nebraska
    53
    here is a small log
  20. #40
    Mar 2022
    Indiana
    3,019
    Alright. There's a problem on that B1 sensor. It's making fuel trims max out. You can either figure that out or, if you're in a hurry, put the wideband back in. It'd be best to run in CL using both narrowbands, but we can get it close with the wideband right now. Lmk. Sorry about that, but I didn't expect there to be a problem immediately.
    Best configuration is two functioning narrowbands with the wideband being used simultaneously in a different spot.
