Results 1 to 2 of 2
Thread: hellcat issue at wot..!!
    Hi
    i was log hellcat for my frined
    the car in dyno hestated and timing advance read 3 degree
    in street wot before 5 gears its good but in 5 or 6 the car go read 0 - 3 degree
    please i need help for fix it
    i see Friction Torque zero i dont know its good or no
    Advanced Tuner N2speed's Avatar
    Mar 2021
    Pompano Beach FL
    267
    the -5 KR isnt helping either.
    also you have the following codes lot of issues going on here
    P2173 - Throttle Actuator Control System - High Air Flow Detected (Current)
    P2172 - Throttle Actuator Control System - Sudden High Air Flow Detected (Current)
    P2251 - O2 Sensor Negative Current Control Circuit/Open Bank 1 Sensor 1 (Pending, Current, Permanent)
    P00EB - Intake Air Temperature Sensor 3 Circuit High Bank 1 (Pending, Current, Permanent)
    U113F (Pending, Current, Permanent)
    U1140 (Pending, Current, Permanent)
    P023B - Charge Air Cooler Coolant Pump Control Circuit Low (Pending, Current, Permanent)
    U02A9 (Pending, Current, Permanent)
    Controller Type ID By OS: 21122
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
