Results 1 to 7 of 7
Thread: Break in 5.3 to 5.7
    Break in 5.3 to 5.7
    I have 03 silverado 1500 4wd supercharger stage 3 cam e85 .my ? Is how to tune b4 break in procedure since I'm going from 5.3 to 5.7 every thing else is same on new engine jst bigger what do I change so I don't glaze my cylinders?
    Jan 2015
    Arizona
    483
    Quote Originally Posted by Shawnbonay View Post
    break in procdure?
    its a roller cam engine, there is no break in.
    start it, look for leaks, close the hood and get on the dyno for tuning.
    Anything else?
    Quote Originally Posted by bk2life View Post
    break in procdure?
    Anything else?
    I was told I had to make sure rings wear in right forgot what he actually said
    Jan 2014
    SoCal
    1,583
    For the most part many just use 100% NON synthetic for break in. I am usually pretty easy on a new motor for the first 100 or so miles. No WOT. Not to sure what everyone else does but that's just me.
    First oil change at around 500-1,000 switching to full synthetic.
    Aug 2006
    5BA8
    3,430
    If the hone job was done correctly the rings should seat almost instantly. Definitely within the first 15-20 minutes of operation.
    On new engines, I prime the oil system then once they start I'll keep them up off idle for a few minutes. Until the valve train quiets down. Then a quick check for leaks, make sure the temp stabilizes and there's no air in the cooling system, then beat it like a bad kid.
    EFI specialist
    email=[email protected]
    Hell yea .I got the engine from summit with forged everything. Got the melling high flow oil pump as well and jst ordered amsoil 30 break in oil my lifters are only 1500 miles on them so should be good .thanks guys any do I add for fuel to my ve b4 first start since it's bored?
    Jan 2014
    SoCal
    1,583
    Whatever it is bored to will add displacement. Just add that displacement to the "Cylinder Volume" at [ECM] 2001.
    That will take care of it. VE still needs tuning but you are removing a variable thereby reducing a cumulative error.
