Results 1 to 4 of 4
Thread: 2017 RAM 1500 5.7 issue
    Mar 2006
    Regina, Saskatchewan
    141
    Hello Everyone,
    I am tuning an neighbor's truck. its a 2017 Ram 1500 5.7
    They sent the PCM off to another vendor for unlock service. the service clearly states they offers PCM unlocking for HPT usage.
    I did a vehicle read and once i open the read file it wants me to license it.
    I proceed and did the I agree disclaimer.
    now when i proceed to write the MDS disable change its telling me i need to license the vehicle.
    Best i can tell is the PCM is licensed but the TCM is not. I assumed i only needed to license the PCM.
    do i need to do a PCM only read? or remove the TCM controller from the first read?
    Im new to turning these 2015+ rams and never had to deal with this before. some help would be appreciated. Only touching MDS so assume PCM is only one needed? or do i need 2 credits for each? 4 total for that vehicle?
    Chris T.
    2014 F350 6.7 Powerstroke.
    2008 Ford F350 Super Duty 6.4L 72MM turbo
    2007 Escalade 6.2L
    2007 Yukon Denal 6.2L
    2010 Lexus RX350 3.5L
    2001 Tacoma 3.4
    2000 Camaro SS LS1 M6 - STS Turbo
    1998 Dodge Cummins 12v 5spd
    1998 Topkick Cat 3126E 7.2L
    1983 Toyota Pickup
    1982 Toyota Pickup
    2006 DRZ400
    2008 Turbo Nytro
    2010 Skidoo XP 800
    1978 Corvette
    Jan 2022
    914
    Naw, you only needed 2 credits to write to that pcm
    You will need 4 more if you want to write to the trans
    You might want to post this in the proper sub forum. The HPT crew is not in this one very often
    https://forum.hptuners.com/forumdisp...?79-VCM-Editor
    Mar 2006
    141
    Thanks I got my answer in that other sub forum. I had already proceeded with doing pcm only read so I wrote only pcm it seemed to work as it should.
    Jan 2022
    914
    yer welcome
