Results 1 to 5 of 5
Thread: Lots of graphs, can't scroll or display them? Not sure why...
    Apr 2012
    3
    Hey guys, long time listener, first time caller.
    I've changed laptops to a smaller screen as I wanted something lighter but something i've noticed with the graphs layout I cannot work out. I have LOTS of saved graphs that I use for all various tuning layouts but i'm unable to scroll or select the ones further down the list (see pic). I can click on the lower section of the graph list, but when I try to click on a graph (Knock Retard for example) it will not show up.
    Am I going nuts here or is there something obvious i'm missing or have I found a bug? The only way for me to open up the graphs as a work around is to make the graph window larger (drag it down), select the graph, then drag the window back up to make it smaller.
    Cheers!
    Kris
    2,915
    You can make another graph tab and break up how many you have in one. Go layout - add to lay out- graphs. I have 4 separate tabs of graphs on mine.
    Tuner at PCMofnc.com
    7,887
    Same behavior here, you aren't doing anything wrong.
    2,915
    You can see what I'm talking about here.
    I tune GEN 3- 5 with this thing daily. So I try to make my scanner super dynamic. You will have better scanner performance if you only have the tables you need.
    Apr 2012
    3
    That works! Probably the best work around for me. Thanks for the tip!
