Results 1 to 7 of 7
Thread: Strange Intermittent InjPW during Cranking/Running
    Sep 2019
    43
    Helping diagnose a problematic 2022 Charger Whipple car with fresh install. Reportedly car would run for short time then just die.
    Today, it will not start at, and multiple sessions of cranking shows 0.0000 Fuel Mass or PW. EXCEPT Once, during cranking delivered a flare of PW and she fired and ran for about 2-3 seconds, that shut due to a cut in PW.
    Different tunes, original tunes, etc., all tried with same results except the one firing.
    What factors would keep PW for being commanded, without codes or other clues, and yet still allow ONE firing...?
    Thx for any ideas on where to check next?
    ?First quick fire.hpl
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    590
    Are you sure you got fuel pressure ?
    get the injectors power supply?
    Sep 2019
    43
    Yes, did confirm good FP at rail.
    Have not yet checked injectors with noid light, but would seem the PCM is not ?commanding? PW vs. injectors power being interrupted.
    Unless the PCM can see the feedback look?
    May 2018
    Germany
    590
    What about anti theft system ?
    Sep 2019
    43
    Hard telling if something got messed up. Not obvious, but I can try disabling then IMMOB options and see if that helps.
    I did validate that the TPS is not responsive to KOEO initial cycling or Pedal input. I checked another 2022 and throttle blade moves with key on and input.
    Could there be a strange correlation between TPS issue preventing PCM from giving fuel (but still not throw a code)?
    May 2018
    Germany
    590
    For something like this AlfaObd would be a good tool to test the components of the system.
    Aug 2021
    Yorktown VA
    200
    Check voltage at the fuel pump controller, if controller has been removed, then at the fuel pump connector, testing voltage to ground first during priming and then again during cranking and see if there is a voltage drop between the two. Could be priming fine so rail pressure looks good, but have a voltage drop during cranking. I would test this first.
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
