Results 1 to 7 of 7
Thread: Help Stuck away from home
    Aug 2021
    19
    Unhappy Help Stuck away from home
    My 06 Silverado with L96 6.0 Swap was running good before this issue. I was traveling down the freeway when all of a sudden it started stalling and back firing lost speed, I made it to a town where I was able to change the MAF thinking that was it but Im still having the same issue and its getting late and have the family with me Any help will be greatly appreciated.
    I have attached Current tune and logs. Log that is labeled First Test its actually what I Logged with issue before changing the MAF.
    405
    2,357
    Using a Lingenfelter TRG-200?
    Aug 2021
    19
    no reluctor wheel was changed
    Aug 2021
    19
    Truck was running good and have put 12k miles since swap
    13,595
    Both logs show pretty lean fuel trims with the 2nd log showing the long terms at +25%.
    Could be losing fuel pressure.
    Aug 2021
    887
    Trims show pretty lean. I'm not much for diagnostics but you aren't getting adequate fuel. Check the fuel system for leaks, bad pump etc. Also, you have a Camshaft position sensor Code.
    Aug 2021
    19
    i appreciate the input, will see what i can do on the fuel pump side not sure if I will even be able to change that without the right tools. thanks to all
