Results 1 to 11 of 11
Thread: Changing my rear mufflers changes my STFT
    Jan 2024
    6
    LS3. Straight pipe guttered Cats. 3" Catback. Mafless Tune. LTFT disabled. STFT Only (The tuner did this, I only understood what was happening after learning up on this stuff)
    I noticed with my 3" rear mufflers (Free flowing), my fuel trims show a bit leaner. Around 5% mark. When I swapped out to factory (Ultra Silent) mufflers, my fuel trims drop down to 0% mark.
    Is this some type of back pressure effect? And how could I get my fuel trims to drop back to 0% with the 3" mufflers without going to my tuner first?
    Jan 2024
    6
    That was actually my original post, but I wrote a novel with multiple questions in the post and likely confused everyone. So I separated the threads as the questions were not really related. Unfortunately it wont let me change the thread title or delete the post to re-write the thread title.
    Nov 2017
    1,567
    Quote Originally Posted by Xplaya View Post
    Really, it's usually all related, you just don't realize how.
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,038
    Short answer: YES, exhaust configuration will impact volumetric efficiency.
    When I was a calibration group manager at a major OEM, I had a dozen different programs that all used the same long block (displacement, CR, heads, cams, intake), but each one needed a unique VE model to account for the various exhaust systems in the different vehicles. Your example is no surprise.
    Nov 2006
    2,959
    Day to day will change your STFT. They will never be perfect in all conditions.
    Tuner at PCMofnc.com
    Aug 2006
    5BA8
    3,549
    ^^^^ I'd add a 5% swing (from 5% to zero%) is no big deal. You can't really get them much tighter than that. OE stuff typically isn't that close.
    EFI specialist
    email=[email protected]
    Jan 2024
    6
    Is it OK to keep the car at +5%. My understanding anything outside -10 / =10 mark is the no go zone. But dont really know if the numbers are OK to stay between -10 to +10 besides 0
    Nov 2017
    1,567
    To me 10% is excessive, I would rather keep it below about 5%. Get more logs on long, typical drives and see what it does.
    Aug 2006
    5BA8
    3,549
    Is +5 the average or the peak? Does it bounce over +10? Just saying "+5" doesn't really explain how the vehicle is running. As far as I've seen you haven't posted any data logs, before or after, so it's all just speculation.
    It can't be "+5" all the time, everywhere. So it's all going to depend what a long data log would look like plotted out against the airflow table of choice.
    EFI specialist
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    250
    Living in high altitude I have seen stock cars swing 10-15% going from 5k altitude to 12k+. Dont chase your tail on the trims. Within 5% is perfectly fine.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
