Results 1 to 12 of 12
Thread: 89 Trans Am 3bar sensor in Torqhead LT1 Procharged
    Feb 2006
    Canada
    1,963
    Hopefully a easy one... MAP sensor is reading about 10pa low. Found what I thought was the right offsets for the sensor, but reads 85kpa key off and is idling in the 40s, not right. Anybody else done a 3bar TA Turbo MAP in one of these and got it right?
    2000 Trans Am WS6
    Nov 2017
    1,544
    Map Part number?
    Feb 2006
    Canada
    1,963
    DELPHI PS10081/18023 is what I installed, got it from Rock Auto for an '89 Turbo.
    2000 Trans Am WS6
    Nov 2017
    1,544
    Those part numbers don't show up with a search on here and they don't cross reference with anything that will have a tune that HPT will have been able to read.
    But I did find this. I can't open your tune to see if your numbers match. Linear 315.58 offset 1.11.
    https://www.pcmofnc.com/2020/03/12/g...r-2-bar-3-bar/
    Feb 2006
    Canada
    1,963
    Different, I had come up with 329.45 and -6.35 for 3 Bar... Ill try that as soon as I get these miserable spark plugs done here. Thanks GT, I'll post back when I do..
    2000 Trans Am WS6
    Nov 2017
    1,544
    Just because a sensor is a 3 Bar (or 1-2 Bar) doesn't mean they have the same values.
    Edit: Just noticed your post count, so you probably already know this and I misread your last post.
    Feb 2006
    Canada
    1,963
    This 3 bar is 100% new to me. Was a post in here that had been talking about the 89 Turbo MAP and had the math to go with it. I thought I had the same sensor they did there. Your not wrong bud, lol
    2000 Trans Am WS6
    Nov 2017
    1,544
    Theoretically, 3 Bar for the same application should have the same values, but it seems like the sensors for old applications are all over the place. If the values I posted don't work, you may have to apply known pressure to the sensor, measure the voltage and do the math.
    Nov 2017
    1,544
    If I did the math correctly, the values I posted will give you 88.614 kpa. What altitude are you at?
    Feb 2006
    Canada
    1,963
    Under 1000'. MAP sensor will read 100 or so KPA, Key On here.
    2000 Trans Am WS6
    Nov 2017
    1,544
    You may want to check your voltage at the sensor key on engine off and do the math. If it works that way, check the wiring.
    Aug 2006
    5BA8
    3,486
    I'd bet those numbers get him a lot closer to reality KOEO.
    EFI specialist
    email=[email protected]
