Results 1 to 11 of 11
Thread: Can Am X3
    Jul 2009
    Oklahoma
    6
    Can Am X3
    Hello all, I have been working on my first Can Am. The machine is a 2018 X3 x rc turbo r. I have a couple of questions for guys dealing with these daily. 1. After applying the extended datastream patch, should I be seeing more channels for fueling? I am not seeing injector duty cycle or injector pw. 2. Is this ECM one that only has the "write entire" option? I have searched and have only found answers on other ECMs supporting only "write entire." 3. Are you guys using the MAP or TIP for accurate readings? I am seeing a difference of a few psi between the two.
    Thanks.
    Jul 2009
    Oklahoma
    6
    Quick update, number 2 has been solved. These ECMs only have the write entire option.
    Oct 2016
    9
    Ok Here's a dumb question what is a extended datastream patch, what does it do and where do I get it? Thanks
    Apr 2021
    18
    Quote Originally Posted by suprsky View Post
    It's under the os tab in VCM editor. It allows you to log more parameters.
    Jul 2009
    Oklahoma
    6
    Another update, I still am not able to log all the things I would like to see. Injector PW or duty cycle being the most important. I am making some headway though. Any insight is appreciated on the logging situation.
    Jan 2022
    Galloway NJ
    148
    Quote Originally Posted by LCW View Post
    did you do the extended datastream?
    Jul 2009
    Oklahoma
    6
    Yes, I did.
    Jan 2022
    Galloway NJ
    148
    Yes, I did.
    open a ticket with HP Tuners and let them know you cannot see PW and duty cycle.
    we had to do that with the seadoo version, they had to add that functionality.
    Jul 2009
    Oklahoma
    6
    I will do that. Thank you for the info.
    Mar 2023
    13
    Quote Originally Posted by Tbranella View Post
    Hi, sorry for having nothing to do with the post, could you tell me how to delimit the seadoo 325 with the buds?! The thread where you mentioned it is closed. Thank you.
    Jan 2022
    Galloway NJ
    148
    Quote Originally Posted by JT_alex View Post
    check your PM.
