Results 1 to 15 of 15
Thread: Mid range lag
    Mid range lag
    Hi I'm having some mid range performance issues. The issues is between 1800 and 3300rpm its acting almost like turbo lag but there is no turbo. Once PE kicks in I can really feel it pulling.
    I Just installed a 6.4cam with 6.4 springs and shorty headers in a 5.7hemi 2016 pursuit awd
    My Tune and log is posted looking to get this fixed. High rpm is really good just can't figure out the middle.midissuegoodhigh-work.hptlog.hpl
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    2,284
    well yeah
    look at how retarded you are running the camshaft
    it is running exactly as it is commanded
    tuned by tank [email protected]
    well yeah
    So I should run the 6.4 values from a stock set? It's my understanding that the 5.7 will only read cam angle up to 125
    Jan 2022
    fountain valley
    2,284
    125 is full advance and where it starts off
    at part throttle you have the cam retarded over 40 degrees from there
    if you hold the intake valve open for an extra 40 degrees how much stroke is left to compress the mixture?
    ok so i should bump that up to say 100 and try that
    Quote Originally Posted by hiwiredjuice View Post
    Its really hard to see any "lag" when we have no idea what the Pedal is doing.
    Speaking of Pedal, You have some crazy DD and ETC stuff going on, don't wreck your car
    If this lag is supposed to be at Log time 00:17:13.0123, there looks like two different issues. One before the 94kPA MAP spike and one after it.
    Below 94kPa Map, it sure looks like WOT delay even though it appears disabled in the tune.
    After 94kPa spike, the Expected Torque is suspiciously flat until the TB decides it wants to open up more but the MAP is maxed out at Open Loop PE .
    I'd look at more info, like the aforementioned Pedal, all the Torques and Airflows as well as the Converter Clutch, AWD and Trans parameters. Then see if there's a clip on Airflow or Torque.
    Advanced Tuner Spray-Cam Hell-Ram's Avatar
    Aug 2021
    Yorktown VA
    251
    Yea, lots of odd stuff going on for sure.. but try this... maybe it'll help out a little and get you going in the right direction...
    "1MEAN16" Silver/Black 2016 Ram CCSB (4592lbs) NA 398ci Stroker
    +6cc Mahle Dome Pistons w/ 12.8/1 Compression on E85
    Forged 4.08" Stroke Crank, 224cc AFR Heads w/ Titanium 2.165"/1.62" Valves
    Custom Cam 220/237 .627/.589 108 LSA 103.5 ICL, 105mm Hellcat TB
    Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/125 Shot(4 sec)
    Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
    Dual 450 Pumps, Deatschwerks 1000cc Inj, Fuel Cell in Bed
    Built 8HP70 w/ 3800 stall/Detroit Tru-Trac/410 Gears
    Jan 2022
    fountain valley
    2,284
    Quote Originally Posted by Spray-Cam Hell-Ram View Post
    that is basically what i was suggesting...
    (bring max airflow back onto this planet and work on the cam tables)
    spray cam mighta tweaked more cam tables than your car or truck is gonna want tweaked
    there are three that i personally woulda tweaked further
    bet that ^^^ is a improvement tho???
    Thank you for the help i appreciate it.
    I updated everything in the tune. I didnt take a very long log and i stopped a couple of times but the mid range issue seems to be fixed but now im getting knock
    suggested.hpl
    Jan 2022
    fountain valley
    2,284
    can you see that screen shot?
    this is what i was saying in my message
    4.4v at 25% throttle nfg
    I see it went from 110 and was fine no knock to 120 there is knock.
    So the correction would be to set the exhaust cam to 110 in that rpm range? or pull timing?
    Jan 2022
    fountain valley
    2,284
    i wouldn't want it back 10 degrees there... maybe 3
    but that is not why its freaking out
    and 20 degree lead is not making 4.4v at 20% throttle either
    i believe it has to do with errors in the other cam tables
    i can fix it
    shoot me a email
    i can fix it
    shoot me a email
    OK sent you a email to the one at bottom of your post
    Jan 2022
    fountain valley
    2,284
    your laptop has OneDrive on it
    HP Tuners and OneDrive are not compatible
    attach the current tune here
    I think I may have got it i will keep you posted
