Results 1 to 3 of 3
Thread: Very rough idle on STOCK platform
    Oct 2016
    6
    5.3 with 4l80e swap c10
    stock intake injectors everything stock besides header
    BP stand alone harness
    will run rough smooth out then rough again need to get second opinion im thinking ECM bad
    also headers have different temps on each temperature cylinder some are 150 other at 300
    1,858
    If random cylinders are different temperature, it’s not a tune issue, unless you are talking about one bank vs the other. This is a mechanical/wiring issue.
    1,858
    And you should post in the section that applies to your ECM for more help (GM gen 3, 4 etc)
