I need help with the tuning of f250 6.2, there are many maps, I would like to know which maps can be modified
I will be grateful
I will be grateful
Sounds like you need to learn about Ford's HDFX logicPlenty of good reads here on the forums of how it works or other places online.
https://forum.hptuners.com/showthrea...he-newer-Fords
JTC Performance - Authorized HP Tuners Reseller
Remote performance tuning
Thanks brother for the information
HP Academy has some information about tuning the Ford 6.2 using HPtuners hardware/software.
Off Road/Quarter Mile Drag Car/Not Street Legal
2018 base Ecoboost Mustang, 10R80 automatic transmission and 01A optional factory electronics
Modifications: Custom dual feed 3x3x4 air intake, NX 11910 Turbocharger, Aftermarket and custom charge pipes, Turbosmart plumb back BOV, Air to Air intercooler, Auxiliary water to air Intercooler, Port Injection kit with auxiliary controller, 3" turbo to rear axle drag pipe, trunk mounted battery and icebox, Drag radials.
Good morning brother, can you help me with the Hp Academi link?
Start simple make some timing changes in the map points utilized (enabled) in the VCT settings. At specific cam angles the PCM will use the same map point timing map some times averaging between 2 corresponding map points. You can usually go to the VCM Scanner and select the map points enabled and as the trucks runs see which map point is being used from there also view the retard / advance pids and see where the vehicle can have some changes made. Ford usually tunes these engines for max efficiency vs hp so there is always some left on the table but usually at the expense of MPG. You can also play with your Driver Demand table for a better pedal feel & response small changes are key until you get the hang of tunning your own vehicle. You can also play with the transmission TQ management to get the shift points crisper and more potent increasing the last 3 cells by 1.20 should give you a good place to be at WOT to start.
King Ranch Expedition 5.4 3v 6R80 Coyote PCM , M112 Blower, Kooks Long Tube Headers, Green Cats, Aeromotive Regulated Return Fuel System, ID 1000 Injectors, Custom Interior Wiring, Track Apps, EPS mode adjustable, +6 Blower Pulley w/ Innovators West SFI Balancer, Afco Dual Fan ZL1 Heat Exchanger, Flex Fuel E85 0-60 5 secs 12.0 best quarter mile time.
14 GT500, 13 Mustang Custom, 03 Aviator 4x4, 16 Navigator Reserve 4X4
