Thread: PCM swap PT Cruiser 2.4 Turbo
    May 2024
    10
    -I have a 2006 PT Cruiser 2.4 Turbo
    -The is an internal code to PCM , (I don't recall the number)
    -The issue is no speedometer - no cruise control .
    -Transmission performance is good , so is engine
    -I found a 2003 PT 2.4 turbo PCM , I compare pin out vs 2006 PCM , most fit the pin location
    but the 2003 does not have CAN communication at pin 34 and 35 See pdf files for pin out
    -The PCM looks like the one on my 2007 Magnum , same connectors . does that make it NGC4 ?
    -Do I just read my 2003 PCM , Install the 2006 the push software from 2003 to 2006 and Bingo ?
    Thanks , Marc2003 PT.pdf2006 PT.pdf
    SoCal
    1,813
    Start here and see if the hardware is the same. Unlikely it is unfortunately.
    I have purchased a few PT Cruiser PCM from here. Price is good but there were times that it took a couple weeks to get.
    https://www.fs1inc.com/chrysler-dodg...computers.html
    May 2024
    10
    I saw these guys on ebay I think. I made the bet already buying the 03 PCM . Since the connectors were the same and because NGC4 can have very different options depending
    on what year vehicle they are , 75$ was a cheap bet . I will keep this updated. Thanks !!
    May 2024
    10
    I'm Late !!
    I did install the 2003 PT Turbo PCM on the 2004 , changed the VIN with my Snap On Solus
    Car runs great , speedo came back to life and cruise control is working as it should
    Strangely , we lost the Fan control and I have a code for AC pressure too high.
    although no fan relay codes.
    I suspect a different pin out , specially for AC pressure.
    I will read the car and see if some change can be made.
