Results 1 to 11 of 11
Thread: 2017 Lincoln Ford MKZ Fusion 2.0 Ecoboost
    Mar 2024
    Texas
    6
    Just looking for anyone to dummy check my tune, with all the reaserch ive done this is what i came up with so far. If anyone has better insight please let me know. She's a heavy girl and just trying to put some more pep in her step. Any advice is appriciated.
    Attachment 148035
    Attachment 148036
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    277
    I'll have to look at it more when I get a chance, but what little I did look, I see a few things that I would change.
    Mar 2024
    Texas
    6
    Some advice would be much appriciated.
    Mar 2024
    Texas
    6
    Quote Originally Posted by skylinedan View Post
    Any chance you had some time to look it over?
    Sep 2019
    Toledo Ohio
    277
    Been super busy, and to be honest I forgot all about this, LOL. I'll get a look in the next day or so, let you know what I see.
    Are you just looking for more power? Is your tranmission shifting well? I picked up a few MPGs messing with the timing on my 13' Fusion 2.0 awd.
    Mar 2024
    Texas
    6
    I am basically trying to squeeze as much power out of it as I can thats still considered "safe". The trans is shifting just fine with the little adjustemnets I made to it, just dont have enough knowledge to get the most out of it just yet.
    Sep 2019
    Toledo Ohio
    277
    Trans tuning isn't to bad, just keep it simple, bump your shift pressures a bit, and lower the slip times. There's a bunch more stuff you can adjust, but it takes a lot of trial and error. I still need to get a look at your file, been trying to dial mine a little better after going back to straight 93 for now. E30 is fun once you get it dialed in good, but finding more than one gas station sells E85 around here has been a pain.
    Mar 2024
    23
    Could you post the stock read please? I can help out a bit.
    Mar 2024
    Texas
    6
    Arrow Long awaited stock read....I know, I know
    Here is the asfound as requested.
    May 2021
    Between Florida and Michigan
    98
    Thanks for sharing your stock tune! It will be interesting to compare it to the stock tune of my 2014 2.0 Ecoboost Fusion.
    Am I correct in understanding that your 2017 2.0 is a TS (twin scroll turbocharger) w/ semi open engine block deck, and do you know the factory HP? My 2014 is equipped with the single scroll turbocharger w/ semi closed engine block deck, and was factory rated at 240 bhp.
    Off Road/Quarter Mile Drag Car
    2018 base Ecoboost Mustang, 10R80 automatic transmission and 01A optional factory electronics
    Modifications: Custom dual feed 3x3x4 air intake, NX 11910 Turbocharger, Aftermarket and custom charge pipes, Turbosmart plumb back Bypass Valve and auxiliary Tial BOV, Air to Air intercooler, Auxiliary water to air Intercooler, E85 Port Injection kit with auxiliary controller, 3" turbo to rear axle drag pipe, trunk mounted battery and icebox, Drag radials.
