Results 1 to 9 of 9
Thread: Need a stock FICM file
    Dec 2020
    15
    I have a new to me 2004 6.oh, I am able to read the ECM.
    The FICM was replaced with a rebuilt module and I cannot read it. How do I go about obtaining a stock or equivalent FICM file?
    OS that is currently on the FICM is PRZ2AL10.
    Dec 2020
    15
    Anyone?
    I tried emailing Powerstroke Customs and the email came back as undeliverable.
    Can I flash a file from another FICM with a different OS on to this FICM? I have a FICM file from an 05 and 06 that is stock.
    May 2024
    7
    VCM editor should ask you if you want it to generate a 'stock file' since the FICM can't be read. This is the case with any of these FICMs as their software/hardware is not capable of reading the FICM so they generate a stock one based off of the OS and tie your VIN to it for licensing purposes.
    If you were to flash a file from another FICM, you'd be licensing the VIN from the other file and it would not match your truck's VIN.
    Dec 2020
    15
    Thank you for the reply! I tried reading the file like you suggested and a stock file was generated. However, when I open the file, I receive an error
    "Validate Checksum Failed. You will be unable to save or flash this file"
    May 2024
    7
    Make sure you are using VCM suite beta and it is updated. Are you reading all or only the ficm when you get the checksum error?
    You can try submitting a support ticket, they may be able to fix the file.
    Aug 2023
    canada
    92
    Quote Originally Posted by RDTRCTR View Post
    Anyone?
    send an email to [email protected]
    Dec 2020
    15
    Sent. I figured out in the first email attempt that I misspelled Powerstroke...
    Thanks a ton for your help!
    Jun 2024
    11
    Were you able to get a stock file? I cannot get a stock file for mine, i keep getting a checksum error and i am never offered a stock file through vcm editor
    Aug 2023
    canada
    92
    contact me as [email protected] and i can send you one.
