Originally Posted by
Fredly1
Hey everyone. I apologize in advance for my lack of experience in this area. I have searched and was not able to find anything that would work. I?m getting down to the end of my build and I?ve run into a roadblock. I have an 08 LY6/4L80e in my 67 Camaro. It has an E38 and PSI harness. I have a generic dual fan setup with Deralle relays. I hooked it all up using the ground trigger from the PSI harness. I can get them to turn on and off with the Scan program but it will not come on otherwise. The stock motor had a mechanical fan. I had read to use the fan settings from a 2010 Camaro SS but it still did not work. I was trying to have 190/185 & 205/200 for on off settings. The car does not have AC at this time How can I get this to work properly? What settings should I use? Thank you in advance
