Results 1 to 14 of 14
Thread: Newbie questeion..
    Aug 2022
    ontario canada
    10
    Newbie questeion..
    have the mpvi 2, and have used it a bit, saved some tunes, did some changes and saved them, haven t used it for quite sometime, wanted to change fan temps on my C5, I did a read and saved it, closed everything, then opened up and found the one i just did, opened it up and made the temp changes and turned key on, plugged in the tuner to laptop. waited for a bit, hit write and waited until was complete, closed it, waited another 15 seconds, unplugged, key off, then opened the file to be sure it was good, nothing changed, it didn t save my changes. My question is did i miss something, do something wrong ?
    any advice would be appreciated
    thanks Al
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,755
    If the write completed whatever file you wrote to the ecm is what is in the ecm.
    You can open a support ticket here https://support.hptuners.com/
    Nov 2017
    2,711
    "opened the file" or read the file again?
    Aug 2022
    ontario canada
    10
    I need to read the file again ?
    I opened it after writing, but didn t read it again after writing.
    Aug 2022
    ontario canada
    10
    didn t read after writing.. maybe i need to do it again then..
    HP Tuners Support
    (foff667)
    28,755
    why would you need to read after writing?
    Nov 2017
    2,711
    It will write whatever changes you have made in the open file that you are writing from (I think, I always save the file before writing). But you have to save the file before closing it. So, the file you opened isn't necessarily the file that is in the ECM. You shouldn't have to reread it, but that is the only way to 100% know that the file change "took".
    Edit: Not directed at Bill of course.
    Aug 2022
    ontario canada
    10
    because I would like to see that the changes where applied and saved.
    Aug 2022
    ontario canada
    10
    that is exactly why i would like to.
    thank you
    HP Tuners Support
    (foff667)
    28,755
    If it says completed, it took.
    With that said, not all applications allow reading of the file that is currently in the ecm. More and more newer vehicles, in particular, cannot be read natively and we provide a stock file. With that said the C5 corvette whatever you read is what was in the ecm.
    Having to reread the ecm is rarely suggest as anything more than a proof of concept tbh.
    Aug 2022
    ontario canada
    10
    ok thanks Mr Bill.. appreciate your time on this trivial matter.. have a good day sir
    Nov 2017
    2,711
    As confused as some newbies are, I'm not sure that I would trust that they are writing the edited file they think they are writing. And even I get confused when I go back to my tune after being away from it for an extended period of time. Of course, I don't plan on tuning anything new enough to not be able to read.
    Aug 2022
    ontario canada
    10
    lol thanks.. i have changed the tune in it before, and worked ok, but not using it for 2yrs, i forget.. don t get old mon ami'
    Aug 2022
    ontario canada
    10
    well i read it again. and the changes were applied and saved, just as mr Bill and gtstorey had stated. There was no way i was doubting you gents,
    was doubting myself. my confidence has been restored.. lol
    thanks very much gents.
