Results 1 to 7 of 7
Thread: 2010 Jeep Wrangler 42RLE Shift Tables XDF
    Sep 2023
    253
    Attached is an xdf file for a 42RLE transmission in a 2010 Jeep Wrangler for the shift tables. The shift tables are not labeled as I have no idea which is which but the throttle axis and the output shaft speed axis is correctly set. Anyone who uses this will need to figure out which table is which. If anyone desires to have the lockup tables added to the xdf just let me know here.
    Sep 2023
    253
    Here, added the lockup tables to the xfd anyways, it was quick and easy. also added what i am pretty certain is max line pressure while in gear parameters.
    2010 Jeep
    Jim,
    This is the stock file I am trying to get transmission shift tables for. HPtuners is not willing to do the work to add the parameters to the definition.
    Sep 2023
    253
    You have it saved as 2010 but it says in the file 2007
    Sep 2023
    253
    Give me a bit and I'll post up an xdf, you'll have to figure out which table is which though
    Sep 2023
    253
    Here you go
    It is a 2007 thank you I just need to figure out what tables work on this one.
