Results 1 to 3 of 3
Thread: Low Speed Throttle Cut_LGX
    Jul 2024
    Albany, NY
    1
    Hello, I am working on a 2018 Camaro LGX, manual. I have a very strange issue that seems to happen at less than 30 to 40 mph. I will command WOT on take off but the TB is only opening a 1/3. I would like to think my torque tables are correct, I am not seeing a Torque and timing cut, just a reduced TB opening.
    At higher speeds and similar RPM if I command WOT, I will have 100% TPS. I am still in process of tuning VVE but, it is strange that I have this issue at lower speeds not at higher.
    The only other anomaly is that Driver Pedal Axle Torque Request is indicating rather high, upwards of 45,000lb-ft...This drops off to roughly axle torque as vehicle speed increases. I am willing to accept that this is not vehicle speed related, but this only seems to happen in the basement, top end seems fine. Any ideas? Thanks.
    Tuner CYN_CRVR's Avatar
    Jul 2023
    Los Angeles
    105
    What mods do you have?
    Upload your current tune.
    Upload your current tune, but it is probably the transmission tune. In stock form it behaves like that in orden to "protect" it self.
