Results 1 to 14 of 14
Thread: VAP Tune- and no, I'm not sharing it...
    I recently gave up on trying to figure out how to tune my F-Type R and purchased VAP's tune with pulley upgrades. I accidentally ordered the wrong bottom pulley, so all I have right now installed is the top pulley and the tune itself. I spoke with the guy who wrote the tune and he said it was fine to run it this way with the tune as-is until the bottom pulley arrives.
    First, VAP says, and I agree, that many parameters that VAP changes to increase power are missing with HP tuners. However, there are quite a few important parameters available for tuning with HP tuners that would be helpful. I can't show you my tune. Truth be told, I paid a lot of money for it, so I'm not really willing to just give that away anyway- but if I did, I could get sued. So don't ask. The answer is no- sorry.
    That being said, it is pretty obvious what Jaguar does to these engines when they put them in different cars with different HP numbers. This engine, no matter what car it's in, is capable of at least 600hp (crank). Looking at the VAP tune, all they really do is raise the limits on the higher RPM bands for your primary tables like boost limits, driver demand, torque control, and fuel parameters (for the most part). Jaguar (and Land Rover) simply retard the top RPM bands to whatever degree they need with all of these parameters. VAP uses WinOSC to do their tuning- I think he said he does over 90 tables in WinOSC for their tune (which is interesting because I count 91 tables in HPTuners that have been changed..). The pops and bangs mod VAP does is not in HPTuners (he told me how he does it), so I'm guessing when he says 90 tables, he's counting the group of tables as one table instead of six. HPTuners needs to add a lot of points in their poling before it will equal WinOSC. I'm not sure why they didn't- the Fords that use this ECU all have MANY more points than the Jag/LR list of points. I wish they would at least try to make the tunable list more complete.
    My point of the post is, I do think you could use HPTuners to unlock much of the potential of this engine if you know what you are doing (which I do not...). I still think there is some locked-up power left to get even with my VAP tune- timing, for example, is still only 25.5 degrees WOT at 6000 RPM, and I know of a couple people that run 27 degrees of timing for maximum power on 93 octane. VAP can't sell a tune that will blow up your car, so I think I can push it just a little bit more here and there if I wanted to. Keep in mind, though, that there are 90+ tables to look at before you are going to get anything close to a VAP tune. But it's doable to a high degree.
    On the other hand....
    VAP does use HPTuners for transmission tuning. Apparently HPTuners is the best software readily available for ZF 8HP transmissions. I spent quite a lot of time watching videos- mostly dodge videos- on how to tune this transmission. I've had lots of offers from tuners to tune my transmission. I decided yesterday to try it myself, only I took a different approach. As far as I can tell, there are two modes to this transmission, normal and performance. There appears to be several shift aggressions and shift schedules, though I couldn't figure out which one was using what shift schedule, so I just made them all the same for upshifts.
    I like the way the transmission shifts in Sport mode when you push the shifter to the left when in drive (I have an F-Type R V8). I don't like the Sport mode's way it keeps the engine in the power band (2000-6500) all the time when driving on the street. Sport mode is perfect for road racing, but it's a little annoying driving around town unless you are treating your roads as a race track. Country driving on windy roads is a perfect environment for Sport mode, but I mostly keep it in regular (normal) Drive mode with the shifter to the right side.
    So after watching several videos, I learned what does what in the transmission tune, for the most part. Luckily the Dodge transmission and Jaguar transmission are almost exactly the same with their tables and tunables. I then compared the tables between normal mode and sport mode for shift pressures, torque management, and several other things and learned that Sport mode is MUCH more aggressive with it's settings. So as a starting place, I simply copied most of the Sport mode setting tables to normal mode- sort of. I copied all the values above about 50% torque, and then smoothed the transition between the bottom and top. I did not change the torque management at all, which I'll get into later. I also changed the maximum torque to match what VAP set for the engine +1%. The transmission appears to have final say on how much torque the engine can put through it.
    My last change was shift schedule. Stock from the factory, the transmission is programmed to shift at 6500 RPM, and the computer does something interesting when it shifts: at about 6300 RPM, Torque Management kicks in, timing is pulled, the throttle is mostly cut, probably the transmission partially releases the clutch (slip) that the gear is in, and it sort of glides up to 6500 RPM from momentum before hitting the next gear. So really it is shifting with full power on at about 6300 RPM. Having seen several graphs of the dyno runs of engines with the same mods mine has, the power really doesn't peak until 6500-6600 RPM or a little bit higher. Ideally, you would want to use as much power as you can for as long as you can, so I changed the shift schedules to shift at 6700 RPM. I left first and second to shift around 6500, and then took the rest of the gears to 6700. Using VCM scanner, it now kicks in torque management at just over 6500 RPM to make the shift, using more power than before longer (the next gear comes in at a higher RPM).
    I left torque management unchanged. I was reluctant to do this at first because Performance Mode actually has more torque management than normal mode. Having moved all of the other settings in normal mode up to Performance mode settings, I probably should have upped the torque management as well, but I forgot about it when I first tested it... Anyway, my best guess is that with more aggressive shifting parameters in Sport mode, Jaguar increased the torque management to keep from excessively stressing the transmission and increasing drivability. When I did my final testing with the lesser torque management, the wheels chirped a bit on each shift up to 4th. My car is AWD, so that's saying something. I think the less torque management is increasing the power after shift, causing the chirps.
    Results were astonishing (to me). It was near 90F yesterday when I did all of my trans mods. Before programming the transmission, I was doing 0-60 runs 3.7-3.9 seconds. After the mods, 3.3-3.4 seconds. In Sport mode the best I did was 3.5 seconds, holding the break and revving to 2200 RPM for the launch. Right now, my regular Drive normal mode (with dynamic mode on) is quicker than any other mode, and it is still smooth as ever for normal driving. I think it is so quick under WOT because of the reduced torque management. That's pretty impressive. I've heard you can knock off .5 seconds of your 1/4 mile time with just a transmission tune, and I believe that's correct. That may be worth as much as a pulley upgrade and tune! Right now I'm about .2 seconds quicker than stock Sport mode, which I'm quite happy with. I may bump it up a little bit after I get my crank pulley- we'll see how it goes. If I'm running 3.1 or better 0-60, I'll probably just leave it as is.
    The video that I found most helpful was this one, though I actually did none of what he did in the video. The important part of the video is that he sort of explains what each table does, to a certain extent. When he would go to a table and explain it, I would compare Performance mode and Normal mode, which is what gave me the idea to combine the two. My thought was that Jaguar wouldn't put settings in Performance mode that would damage the transmission, so I figured I would use that as a base line. It turns out that I'm pretty happy with the base line, and likely will leave it like that. But I thought I'd share this with you guys since trying to figure out how to tune these cars has been such a struggle for me. I've had my F-Type for almost a year now, and there's virtually no help out there on how to tune our cars.
    Anyway, I hope you all find this helpful and encouraging. Don't be afraid to watch Dodge Hellcat transmission tuning videos since they use the same transmission (basically) and have many like- settings. I think the car he was tuning in the video I linked was a Jeep or something, in fact. There's information out there, you just have to be a little bit unconventional digging it out.
    Baltimore, Md
    1,437
    Do you have any datalogs you can post, Ive been curious as to what data streams and sample rate HPT gets on these?
    Also curious as to what headroom is left in the injectors and fuel pump on them. e85 would do wonders on those things!
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Mar 2022
    13
    Quote Originally Posted by c131frdave View Post
    I agree not much help out there, and it?s all uncharted waters unfortunately. I have been using HP tuners for over 15 years, so very familiar with it, mainly GM and Ford.
    I currently have tuned my own F-type R both engine and transmission using HP. I have changed both upper and lower pulleys and also 100 cell cats air cleaner KN pods.
    Currently seeing 14psi of boost under full throttle/demand which I believe is correct for the upgrades. I did run the quarter in 11.29 RWD on just Michelin at 126 miles. I may have seen a 10sec pass if I had gapped my plugs right. The engine was breaking down under boost at 6100RPM. 0.028 seems to work perfectly now. I haven?t got a comparison tune to see the difference nor do I pretend to know exactly how to tune this particular platform.
    However I believe and agree with you that you can change enough parameters using HP to achieve a great result. Oh and yes you are correct 27 degrees of timing is achievable but doesn?t leave much room for error. 100 cell cats and my 2.5 inch exhaust helps with that.
    Baltimore, Md
    1,437
    Ok do you have any logs of your car at the track? Id like to see if this is another HPT BS artist stuff saying they offer support for a vehicle just because you can ACCESS it but its not really comprehensive software you would actually use to tune it properly - like the Nissan VQ stuff yeah you can read a file... but the damn datalog sample is so slow and doesnt show you hardly any of the data channels that exist so its not really useful to tune them at all.
    Mar 2022
    13
    Not sure why you would think my message would be another HPT BS artist !.....i have been tuning and building engines since i was 14. Love my f-types and i am in the process of building a forged engine with pistons and rods etc, I have custom made personally. Happy to email you a clip of the car at the drags. TBH i was actually disappointed as i should of been in the tens. Like i mentioned i didn't gap the plugs right and it was blowing out the spark at 6100rpm. Going back out in three weeks and hoping to run high tens.
    Happy to help if you have any specific questions regarding the tuning using HP. But in a nut shell, you can command all the torque tables and demand to control the bypass valve. I am seeing 13-14 PSi with some belt slip. Timing at 26 and fuel still safe at 11.8. DI engines can even run leaner 12.0 - 12.2 put cast pistons are a limiting factor if to much knock occurs. Torque management reduced allowing to spin the wheels as far as your want or before putting it into a curb LOL. My Short trims at WOT at 6300 rpm were very positive at 12% so i have since played around with the high fuel pressure commanded for the DI pumps and have got them within 4%. If i do run a ten then that should be enough proof HP can support this platform. I have also tuned the Z8 trans using HP. You need to do both to be able to increase the RPM limits.
    Baltimore, Md
    1,437
    I am not sure why you thought anyone was talking about you? I was talking about HP Tuners offering "tuning software" when it doesnt allow you FULL access to everything needed, as the original poster stated the most well known shop tuning those things says they use WinOLS because they cant get access to EVERYTHING they need to properly tune those cars apparently.
    Similar issue to stuff Ive found in the older Nissan world where they will sell you credits for VQ engines, but the data logging is too slow to properly do anything with it - is pretty frustrating
    As far as tuning them yes DI stuff can run alot leaner than "we" are used to in boosted stuff because its a more complete burn so we dont need to run it rich according to wideband to ensure the mixture in chamber is rich enough. Have you put your car on a dyno? You might find that it likes a couple degrees less timing and good bit leaner air/fuel if so. Timing will hurt them alot quicker than leaner air/fuels will on DI stuff
    Mar 2024
    5
    Brother i don't know what i do wrong but 27 degrees of timing advance is mad especially on 14psi
    I got 24 degrees on 0.82-0.85 bar(12psi i think?) have the upper pulley and my own tune aswell and i can say for sure you are able to make power with HP tuners it's all about the patience and willingness to try out stuff.
    Anyways the 24 degrees might be because of charge air temps but i once tried to just set that table to 0 and try that but its just limited by the fuel i guess or some other parameters i didnt test yet i currently run 100octane from Shell.
    I have around 600hp with me running 100-200kmh (that's your 62-124mph) in 7.3 seconds. Wich is 1 second faster than the stock 8.3 i ran back when i got the car.
    I really wonder if the 100 cells do that much for timing advance tho.
    I got me some 200 cells last week since i live in germany and stuff is very regulated here gonna put them on the car soon and see if i get that 25.5 degrees or maybe even 27.
    But its good to hear that im not the only one to tune these engines and get power out of them.
    Mar 2022
    13
    I just finished running mine up yesterday, and down under (Australia) our fuels aren't that good i believe our best pump fuel is your 95. i did find 24 to be about the mas before some knock was present. Once i tuned in my progressive snow performance Di kit methanol/water i saw all of 28 degrees at 6700rpm. Fuel was conservative at 11.8 (0.801 Lambda). With 14-15 psi of boost. Supporting mods are 100 cell cats, 2.5 mandrel bent pipes up to the original rear muffler. Removed the resonators in the air pipes and installed pod filters. And yes both upper and lower pulley's. I was very happy to see the IAT drop during the run once the water/meth was being injected. HP at the wheels was 622 and 1100 nm of torque. I did see some belt slip during the run, but not much we can do given the minimal wrap around the top pulley.
    Finally i few people are willing and able to share knowledge regarding this platform
    Senior Tuner Norris Motorsports's Avatar
    Mar 2006
    Kuwait
    1,585
    HPT supports more than enough parameters to get to your target goals.
    I've used WinOLS, Race, Titanium, TunerPro and HPtuners on this platform.
    All torque limiters are available, fueling and actual timing tables which work more than the others, getting the engine to run decent is end user experience.
    A lot and I do mean A LOT of tuners use canned tunes they've bought from other tuners that were bought from other tuners hence saying HPtuners is inadequate to tune these cars. (As there are no readily available canned tunes to copy from on HP Tuners yet).
    The main platform I've tuned are the SVRs, and they make quite decent power. I've had up to 570whp on 14psi on an AWD dyno, granted meth was spraying. There seems to be a limit to the mechanical fuel pump so having meth is a must on these motors to keep them alive and make them run power.
    Norris Motorsports
    Remote Tuning Services available for
    Mercedes - Audi - GM - Dodge
    Whatsapp: +965-55446651
    Email: [email protected]
    Instagram
    Baltimore, Md
    1,437
    Quote Originally Posted by Norris Motorsports View Post
    Which do you prefer for this platform and why? Has anyone gotten some kind of flex fuel setup functioning with these?
    Mar 2006
    Kuwait
    1,585
    Most definitely the ease of use with HP Tuners. I'm not sure if you've ever tried using WinOLS, but in terms of U/I, HP Tuners wins hands down all the time. (Though Tuner pro is pretty decent)
    Full flex fuel or virtual like the domestic stuff?
    Norris Motorsports
    Instagram
    Mar 2022
    13
    I second that, HP Tuners is user friendly and has the ability to manipulate all torque request tables required to achieve 14-16 PSI. My personal car is making over 600 HP at the wheels, using water meth progressive, 29 timing and 12.:1 AFR. Plus you need HP tuners for the gear box if you want to increase your RPM limits. My two cents
    Oct 2017
    5
    Do a 5.0 converstion to a MT with a hpt, good luck with that, lol)
    WinOLS handles that perfectly. Also no problems to remap whatever needed in a 8hp (and,yeah, try to do ANYTHING with a gen3 8hp with a hpt, good luck with that too).
