Results 1 to 2 of 2
Thread: Maf fuel trim graph setup trouble.
    Aug 2024
    georgia
    1
    I set up a MAF fuel trim graph to log with following the step-by-step instructions found in this forum. I was able to get it set up. During my drive I noticed the rpm in the cell I was driving in did not match actual engine rpm. What I mean is. For example, when engine is idling, in the rpm scale header it shows to be idling at 2800 rpm and at cruise it shows 5800 rpm. I have gone back and checked things over in the graph editor I don't see the issue. Logged rpm is correct in the gauges and other channels in scanner. Engine is a ls2 in a Jeep YJ. Any help is appreciated. I attached tune file and log below. Maybe its tune related. Maybe I don't understand what I'm seeing. Can someone take a look?
    THANKS
    MAF 1.hpl
    jeep ls swap.hpt
    Tuner Balakayt.'s Avatar
    Jul 2024
    DFW, Texas
    66
    On the maf histogram you should have it set with Hz at the top. RPM isn't used in that histogram. But i dont see RPM being logged in the Chanel list either.
