Results 1 to 12 of 12
Thread: Another l5p tune
    Aug 2024
    North Dakota
    6
    Another l5p tune
    So I have a tune for a 21 l5p that I did for a friend, I have a 18 l5p. Curious what I need to do other than buy the credits to flash the tune to my pickup. I?m not interested in having someone else edit it unless absolutely necessary. Thanks fellas.
    Aug 2024
    North Dakota
    6
    Someone in a different thread informed me the os is going to be different is there someone who has any idea on how to edit the stock tune I currently have? Or interested in trading tunes? This stuff would be awesome if it was open source. I have some ppei tunes for my lb7 and a single 90hp for a l5p.
    Yes the OS will be different and therefore not recommended to ram that file into your truck. You will need a file created based on your OS to make sure everything operates correctly.
    Aug 2024
    North Dakota
    6
    What’s all required to access the parameters to tune the file myself, I have the unlock tool and mpvi3. What else would I need in order to disable speed limiter and other fun stuff.
    Once unlocked you can tune away once license your truck. But there are tuning maps for daysssssssss you can play with on those files.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Jun 2024
    cusick,WA
    3
    i tuned my l5p and i have a u010c c0de im using dummy plug for the s472 everything looks good what should i check
    Aug 2024
    North Dakota
    6
    Comms issue check continuity/load test the circuit, check pin tension. I?ve seen them slip out of the retainer.
    Advanced Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    214
    Quote Originally Posted by Mtxcaleb View Post
    All the parameters you need to tune the truck are defined in HPTuners.
    Western New York's Performance Headquarters
    716.830.0506
    Aug 2005
    Western New York
    214
    Please don't file ram a 2021 file into a 2018. There are not the same OS
    716.830.0506
    Mar 2025
    ok new to this guys so bare with 2017 l5p tuned it now limp mode any thought
    What changes to the stock tune were made? If purchased tune, i'd call them any reputable tuner will work with you.
    Feb 2024
    22
    Did you ever find a tune file?
