Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Unwanted TCS Kicking In
  1. #21
    Nov 2018
    Middle TN
    96
    Did you ever change the stall tq setting and see if it made a difference?
  2. #22
    Senior Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    1,102
    Yes but I have not had a chance to test yet.
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
  3. #23
    Jan 2014
    Australia
    2,055
    im not sure how it all relates as i havnt had much luck getting repeatable data from the TC system with its available data knowing if x adjustment does x affect, but i did notice with yours that the TC max torque maxed out at 8135 if i lower that by the requested torque of 7% (so 7% of the 8135 = 569nm) in your log that is pretty much within 50nm torque of the engine torque u are showing, so im not sure if it is only getting a small TC request but that small request is a decent cut based on the huge max torque value ? this prob dosnt go anywhere but just clutching at ideas of a cause, also have u tried setting the limiter to ''calibration'' and not gmlan just encase some background GM setting is affecting it
