Results 1 to 2 of 2
Thread: running problem
    Jul 2022
    11
    running problem
    hi did ls swap 5.3 with 4l60e little hard to start sometimes have to hit gas pedal while cranking when starts idles around 800-1000 rpm put it in gear let off brake starts to move under idle then idle drops to 400-500 sometimes almost stalling give it gas drives ok then when coming to a stop it idles down almost stalling out but once u stop after about 10-12 seconds it will idle up to a 1000 rpm but as soon as u let off the gas it starts to move under idle then in about 15-20 seconds it drops back down to 400-500 rpm almost stalling out any help is appreciated thanks
    14,066
    Always post the tune file and data logs. Hard for us to see what it's doing without those.
