Results 1 to 4 of 4
Thread: False Knock
    Sep 2024
    1
    False Knock
    Hey I just cammed my gen 4 5.3, Dod, VVt delete with a truck norris cam and longtube headers. Upon start up my knock sensors had a code. I believe it to be a false knock. Are you meant to desensitize Knock sensors after cam swaps? I had gotten a mail order tune and I don't know if I should get it retuned to desensitize them.
    What was the knock code? I'd want to take it to a dyno/tuner and have them check with a knock sensor so you know if it's real or not.
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    359
    Knock sensors don't throw codes from reading knock false or real. They throw codes when they have a fault. Bad sensor, wiring, etc. You never want to desensitize knock sensors since they are what keeps your motor from detonating to death.
    2013 CTS-V Coupe M6 - 2" Headers, 3" x-mid pipes, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSX flex fuel kit, DMS 2g under hood tank, ZZP pump, reinforced brick, 3/4" lines, AFCO HX, Griptec 2.4" pulley, solid isolator, 100mm idler, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq on e85
    Banned
    Jan 2022
    fountain valley
    2,379
    Quote Originally Posted by KillboyPowerhead View Post
    two long followed by one short?
    you dont need to take it to a tuner or put it on a dyno to know if knock is real or not. put some really good gas in it.
    maybe post a log in the appropriate forum and ask for help?
