Results 1 to 6 of 6
Thread: 2003 Silverado WOT issue
    Sep 2018
    5
    Angry 2003 Silverado WOT issue
    i have a 2003 silverado 6.0 stage 4 sumit cam 4l80e 3500 stall
    im having this issue were i cant go wot runs fine partial throttle but when i get on it or when power enrichment kicks in it wont acclerate, it randomly started having this issue, it was fine for a long time .. i have changed plugs , injectors coil packs crank sensor , fuel pressure regulator fuel pump, checked everything for the most part not sure what it can be ..
    i have uploaded the tune and 3 partial runs the 33 shows i can acelerate fine partial throttle just wot it get stuck but if I let of the throttle abit the rpm start to go up again.
    Advanced Tuner abc's Avatar
    Jan 2024
    949
    First, please proof read your post's. Trying to make sense of jumbled letters can be difficult and we are not here to be english teachers, we just want to play with cars.
    Second, if what you say is correct and the current config. file was running the engine in an acceptable manner for a long time, then your problem is not in the config. file. I will try to look it over some and peak in on the log files but, your likely issue is on the mechanical side.
    One of the next places for you to look is fuel pressure during a WOT pull!
    Sep 2018
    5
    Yes I have a hard time spelling , but the reason for uploading the tune is to see if anyone has any suggestions of something that might help or if anyone has had a similar issue, I don't have too much experience with this ,thank you for your response
    Nov 2006
    North Carolina
    4,846
    You have one dead O2 sensor. FYI. That won't cause this issue.
    I can't tell if you are pulling back the throttle or the PCM is. Log accel pedal position also.
    Try 640 ftlbs instead of the 639 you are using.
    Sep 2018
    5
    Yea I pulled that 02 and put my wideband in place of it and thank you I will give it a try see if 640 helps
    Jan 2024
    949
    Maxing out desired torque will not fix it. The config. file is not the problem assuming you have not touched it from when it ran proper. I do know this, if you go to 641 to desired torque it will freak some things out, found that out the hard way. I then moved it down to 639 and all is fine.
