Results 1 to 9 of 9
Thread: 23 Hellcat injector tuning issue
    Tuner MadhousePerformance's Avatar
    Dec 2018
    Florida
    64
    Hope everyone is good i recently had a customer bring in his 2023 Hellcat Jailbreak. So we installed a 2.85 upper pulley 180 thermostat catless race mid pipes and the usual 2309 ngk spark plugs and the fic 1000cc injectors. My tuner started doing the tuning portion and it did not like the injector data at all he tried to use multiple data and nothing. Has anyone figured out what could be done to be able to change data and it actually working. here is the stock file if anyone can tell me that be great cause it would not start correctly once it warmed up.
    Banned
    Jan 2022
    fountain valley
    2,379
    if the data (the "data avg" that they supply) does not work you are pretty well screwed
    no one on this end is gonna have the numbers you need
    its trial and error and a losing battle
    ID1050x are $1050 list
    Banned
    Mar 2022
    Indiana
    4,289
    FIC has excellent data. Post it up so we can confirm.
    Post a log of the problem as well.
    Have you bothered retuning the neural network?
    Mar 2024
    23
    This is going to sound stupid and redundant, but also double and triple check data table scaling and file table scaling. It happens.
    Dec 2018
    Florida
    64
    I did gather proper injector data from Fic directly and then tried a set of 1200cc from fic same issue. So we tested injector tuning by installing the factory ones back on and tuning those and the pcm took modding the injector data. but i even opened up a brand new box of id 1050's we used the data from that and still the vehicle did not like it. man adding all these parameters to 23 cars is the stupidest thing in the plnet i say its so much better to tune the 16 hellcats then these turds.
    Advanced Tuner N2speed's Avatar
    Mar 2021
    Pompano Beach FL
    469
    Is this Tiny?
    What is fuel pressure showing in the log?
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    Mar 2024
    23
    If the above does not work:
    Try adjusting these values in the way I did. I'm using a 19' file because I had a definition error with the one you provided.
    stock tune.hpt 43230, 43231, 37842.hpt
    You really only need to adjust 80-240ms on the maximum, and 37842.
    I had a car with ID1050x's + 2.85 with all sorts of startup issues until I adjusted those tables. Hope this helps.
    Dec 2018
    Florida
    64
    yes sir it is ..... Its showing 50 psi idle
    Oct 2016
    Poland
    2,038
    Only for selected injectors...they sell some with really horrible data
