Results 1 to 6 of 6
Thread: 03-04 Cobra Upshift Light disable
    Anyone care to share how to disable that factory shift light in the cluster?
    I did a search here and didn't see anything.
    In the software, I see a shift light tab and it is set to 6250rpm. I assume there is a setting elsewhere.
    Thanks!
    Oct 2007
    Crawfordville, FL
    2,583
    Send a ticket to support and I'll add in a way to totally disable it (if raising it out of the way doesn't work for you)
    Eric Brooks
    HP Tuners, LLC
    Thanks Eric! I looked through every tab and only saw the single RPM adjustment and that did not seem to keep the light from popping on at lower RPM.
    Sep 2024
    5
    There is a table underneath that shows shift light RPM by ECT. Try changing that
    Oct 2007
    Crawfordville, FL
    2,583
    Shift light master switch added.
    Eric Brooks
    HP Tuners, LLC
    can you share the stock file for the cobra ? need the injector data from it
