Results 1 to 2 of 2
Thread: Timing issues
    Dec 2023
    27
    Timing issues
    hello all I'm helping a friend with a 2012 Xterra 4.0 v6 and we were gonna add a couple degrees of timing and the tables looked foreign to me all the numbers were negative ,I'm used to tuning gm ls lt1 platforms but these tables threw me for a loop.if someone could give me a little input that would be awesome I've never seen an all negative table before .thanks for any info
    Nov 2020
    35
    If the tables are like what I've been working with in my 07 Z they are known as trimming tables. The ignition timing OS takes in a lot of inputs to determine the correct ignition timing. Inputs like multiplier tables for IAT, ECT, VVT POSITION, ETC... Not near as comprehensive as it is on GMs. On the Nissan, just add or subtract from the random numbers on the stock files, and adding 1 doesn't necessarily mean 1 degree. I'm boosted and I've got the timing pretty dialed in but it's a little bit of a guessing game with a lot of trial and error. Hope that helps
